Question about Cooper Wiring Devices 1301-7LTWBOX LIGHTED GROUNDING QUIET TOGGLE SWITCH
Need a wiring diagram to connect a photocell to LS 70 sodium fixture
Please give me wiring diagram to connet photocel with auto and manual switch
Posted on Dec 26, 2010
  • 152 Answers
Wire the photocell between the black (hot) power lead and the black (hot) lead to the light .. the white wire connects directly. hold finger over photocell for a minute or so to test.
Posted on Dec 01, 2009
  • Cooper Wirin... Master
  • 5,245 Answers
When could I get an answer to my question
Have you tried contacting the manufacturer?
Oct 05, 2015 | Home
How do you connect a photo cell to a 220v HID fixture?
You can connect photo eye white wire to ground wire, and it will work, since each hot wire in 240V circuit carries 110V to ground.
But this installation is not code.
It is not necessarily dangerous if you are only person working on electric circuits, and you remember what you did, and don't work inside main box without turning off power.
See illustrations.
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
Running a White neutral wire from nearby outlet is best solution.
Or buy 240Volt photo eye.
Oct 12, 2012 | Cooper Wiring Devices 1301-7LTWBOX LIGHTED...
Wiring diagram for cooper 7020040024
Switch is not identified.
Copy following link to see switch wiring diagrams:
http://waterheatertimer.org/How-to-wire-switches.html
Nov 28, 2011 | Electrical Supplies
I have the same problem listed above. I bought a touch and glow photocell at Lowes to go along with a yard lamp with lights on three arms. It is wired exactly as directed. Black to black, power source...
You have 120volt photocell.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#photo-eye
Wiring sounds correct.
Lights are on all the time, even in daylight.
How is the power by-passing the photocell shut-off?
Disconnect ground wire to make sure there is not a ground fault causing circuit to complete on ground wire.
Otherwise the photocell might be bad.
Aug 22, 2011 | Electrical Supplies
I would like a wiring diagram for an outdoor receptacle controlled by a photocell. Photo cell has 1 each black wire, red wire and white wire.
If I understand correctly, you want to add a photocell to existing receptacle.
Start by looking at receptacle:
Receptacle has 3 different colored screws.
Green screw for bare ground wire
Brass screws with black Hot wire connected.
Silver screws with white Neutral wire.
How to wire photocell to receptacle.
Remove black Hot wire off of brass screw and connect black wire to photocell-black wire. This will power the photocell switch.
Connect photocell-red wire to brass screw on receptacle. This will turn receptacle on-off whenever photocell switch turns on-off.
Connect photocell-white wire to silver screw, and this will complete circuit to photocell switch so the switch is able to operate.
All white Neutral wires are connected to silver screws.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 07, 2011 | Intermatic K4221C Photo Cell Control 120 V...
Wireing diagram do not no were thay go three wires
K4221C photo cell page at Intermatic:
http://www.intermatic.com/products/photo%20controls/commercial%20%20industrial/stem%20%20swivel%20mount%20-%20thermal%20type.aspx
Photocell has black, white and red wires on photocell.
Black goes to Hot from breaker.
White goes to Neutral from breaker box
Red goes to Load (light)
Electricians don't guess, they test.
You should have one wire coming from breaker box, and another set of wires going to light.
Separate wires for testing.
Since you are outdoors, stand on dry boards and tape tester leads to wood sticks to keep hands away from power.
Turn power ON
Test each wire to bare ground wire.
Tester lights up on hot wire. This wire should be black.
Hot wire connects to photocell black
Hot is identified.
Test Hot wire to all wires except bare ground.
Tester lights up on neutral. This wire should be white.
Neutral wire connects to photocell white
Now the other cable goes to Load. This cable has a black and white wire.
Connect photocell red to black Load wire
Connect white Load wire to Neutral, along with photocell white.
Ground wires are twisted together.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Jan 11, 2011 | Intermatic K4221C Photo Cell Control 120 V...
Heater keeps shutting off what could it be cant find manual to help
Use this manual to assist you in troubleshooting. http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
The manual will help you isolate the problem.
Things than can cause your symptoms:
1. Pump pressure incorrect
2. Dirty air intake, air output
and/or lint filter
3. Dirty fuel filter
4. Obstruction in nozzle
5. Photocell assembly not properly
installed (not seeing the flame)
6. Dirty photocell lens
7. Bad electrical connection between
photocell and ignition
control assembly
8. Defective photocell
9. Defective ignition control
assembly
10.Line voltage is below 108V or
above 132v
REMEDY corrosponds with 1 - 10 above
1. Fill tank with kerosene
2. See Pump Pressure Adjustment,
page 10
3. See Fuel Filter, page 11
4. See Nozzle Assembly, page 12
5. Drain and flush fuel tank with
clean kerosene. See Storing,
Transporting or Shipping,
page 7
6. Check electrical connections.
See Wiring Diagrams, page 16
7. Replace ignitor, see page 11
8. Replace ignition control
assembly
9. Check for proper line voltage
1. See Pump Pressure Adjustment,
page 10
2. See Air Output, Air Intake and
Lint Filters, page 10
5. Make sure photocell boot is
properly seated in bracket
6. Clean photocell lens
7. Check electrical connections.
8. Replace photocell
9. Replace ignition control
assembly
10.Check for proper line voltage.
Disconnect power equipment
that may be used on same
line
Thanks for choosing FixYa,
Kelly
Jan 09, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Sodium security blinks on and off all night , has replace bulb and works for about a year. then the blinking starts back
is there another light in the vacinity or is the light in question itself pointed at the photocell. most likely scenarios are that the light is pointing at its own photocell so when it is off the photosell senses dark and turns it on but then when light comes on tricks photocell into thinking it is daylight,check position of photocell and adjust away from light source if problem persist could be ballast going bad
Oct 01, 2009 | Leviton 8599 GFCI Receptacle
Photocell and circuit breaker
Hi, Here is my clarification of the instructions for you. The photocell must be protected by at least a 10 amp circuit breaker. The photocell may be installed next to the light fixture. ( not the breaker). Good Luck, this should Fixya!
Feb 27, 2009 | Prime 10 Amp Circuit Breaker
Photoelectric Control (Photo Eye), dawn to dusk, install
Connectthe SUPPLY wire (Black) to the Photoelectric Black. ALL of the white wires - to lights and from supply and on PE - connect together
Redfrom PE goes to all light fixture black lines
Nov 24, 2008 | Electrical Supplies
Cooper Wiring Devices 1301-7LTWBOX LIGHTED GROUNDING QUIET TOGGLE SWITCH Logo
2,301 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
