Question about Kenmore Washing Machines
Washing machine water inlet valve needs repacement. Have pary But do not know how remove washer top to get to the valve assembly. Appears not to open by poping spring loaded fasner.
  • Kenmore Master
  • 2,605 Answers
Try this;
1) Unplug the washer. turn off the water. remove the fill hoses.
2) remove the 2 Phillips screws in the front on either side that retain the console. On some machines, these are hidden under console end caps that must be pried off. On newer models, they’re on the back of the console and you only need to back them out about halfway. On most of the latest models there are no screws, rather there are two clips that you release by inserting a putty knife under the console from the front. apply slight force forward on clips and they'll release as you pull up on consoile lightly.
3) lift the console forward to unhook it from the cabinet top, then up and away from you. it will hang back out of the way if the washer’s away from the wall far enough. unplug the lid switch plug, it'll be the one with 3 wires, usually white, brown and green. then use a large screwdriver to pry up the 2 large clips that hold the cabinet to the washer back panel.
open the tub lid, grab the cabinet and gently pull forward and it’ll unhook from the retainers on the base. Lift the cabinet off and set it aside, you'll need lot's of room, but it is easy to work on.
4) if you now look to the right of the tub at the back wall while facing the unit you'll have access to the valve.
*NOTE, To put the cabinet back on, open the cabinet lid again, now looking down through the lid opening, hook the cabinet front under the washer frame while keeping the cabinet tilted slightly towards you.
Rest your foot at the cabinet base to hold it in place, as you tip it back down onto the base. make sure the 2 notches at the back on the bottom(frame) line up with the notched holes in the cabinet bottom.
Snap the 2 big cabinet clips back into place, If one side’s gapped, it means one of the notched holes is mis aligned. remove the clip on that side, tilt toward you slightly, and push the side down into place. Then re-install the clip.
plug the lid switch in, re-attach the console. and Bob's your uncle.
you should be back in business.
hope that helps,
good luck
Posted on Sep 26, 2009
Fault 49 pops up on the screen
If your washer is a Fisher Paykel Top-Load Washer Error Codes = 49 I found this online by typing "Washing Machine Fault 49" into a google search engine...
Error Fault Condition - Water Inlet Valve Fault.
Repair or Check - Unplug the washer from power. Reconnect any non secure wires on the water inlet valve. Replace the wire harness if it is found to be damaged. If the wiring is okay then measure the resistance of the water inlet valves using an ohm meter. If the resistance of each water inlet valve solenoid is not 60 to 62 ohms then replace the complete water inlet valve assembly.
Parts for Replacement - Water Inlet Valve Assembly or Wire Harness.
Mar 09, 2016 | Washing Machines
THE WATER IS NOT STOPPING, JUST KEEPS PUTTING WATER INTO THE WASHER KENMORE 90 SERIES
There are two possible causes of the water not stopping. First is the water inlet valves stuck in the open position and second is the pressure switch not tripping when the correct water level is reached. Turn off or unplug the machine while it is filling and if the water doesn't stop, the water inlet valve/s is/are indeed stuck in the open position. Replacing the water inlet valve assembly should solve the problem.
But if the water stops, the problem is the pressure switch stuck in the empty position. Disconnect power then raise the console up and hinge it at the rear of the machine to access the pressure switch. It is the part with the small clear hose attached to it. Detach the hose and blow air down into it including the pressure switch itself. Replace the pressure switch if the problem persists.
Click on the link below for the detailed procedure in raising the console and removing the cabinet to access and replace the water inlet valve assembly.
Removing the Cabinet on a Whirlpool or Kenmore Top-Load Washing Machine
Dec 31, 2010 | Kenmore 15864/15862 Top Load Washer
Kenmore model 110 top load washer water drips out slowly, takes a long time to fill tank
Either the inlet hose screens or the water inlet valve screens or the the water inlet valves not opening completely. Check the screens and the water flow from the inlet hoses by removing them from the water inlet valves. The water valves are not opening properly and needs replacing if the screens are clear and the water flow from the inlet hoses are good.
Remove the cabinet to access and replace the water inlet valve assembly. Unplug the machine from the electrical supply then release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and set it aside. You can now remove the water inlet valve assembly and install the new one then reassembly the machine.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Sep 25, 2010 | Kenmore 15864/15862 Top Load Washer
The electronic cold water inlet valves at the top of the machine are leaking. My manual does not list the part and i need to replace it. I dont know the correct part name or number
Water Inlet Valve Replacement Procedure
Cold water inlet valve assembly: Part # 5221ER1003A
Hot water inlet valve: Part # 5220FR2006H
  1. Safety first. Unplug the machine.
  2. Close the water supply valve.
  3. Remove the cold water fill hose and drain the residual water into a pan or bucket.
  4. Remove the two screws on the back of the top panel securing it to the cabinet.
  5. Slide the top panel to the back of the machine and lift it off the cabinet.
  6. Disconnect the wiring harness connectors from the valves. Mark the connectors to make sure you reconnect them to the right valve.
  7. Unscrew the valve assembly from the cabinet and pull it out.
  8. Loosen the hose clamps and remove the hoses from valve assembly.
  9. Connect the hoses to the new valve assembly. Reinstall the valve assembly and the top panel in reverse of the steps above.
  10. Reconnect the fill hose and open the water supply valve.
Jan 26, 2010 | LG WM-2277HW Front Load Washer
Tub completed cycle and wouldn't shut off the water
Is your machine a FAV6800A or FAV9800A? Can you confirm the Model Number and the first two digits Serial Number?
Does water flow into the machine with the 120VAC power plug pulled from the machine?
If it does you have a stuck water valve. If it doesn’t you could have a stuck pressure switch and I can walk you thru how to check in diag mode for that condition.
I know you are frustrated but with some basic troubleshooting we can determine if the issue is a stuck open Water Inlet Valve or a defective Pressure Switch. Because this board doesn’t ask for the Model Number or Serial Number we need to start there.
Here is where the Model and Serial number info is located on the back of your machine.
Jan 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water pooling in washer in between loads
The problem is caused by a leaking water inlet valve and the only way to solve it is by replacing the water inlet valve assembly. It is an easy "do-it-yourself" fix that only requires a minimum effort.
  1. Remove the three screws at the back of the machine holding the top cover.
  2. Slide the top cover to the back and lift it from the washer.
  3. Put a bucket or pan under the inlet valves.
  4. Remove the fill hoses from the machine and drain the water into the bucket or pan to avoid flooding your floor.
  5. Remove the screws holding the water inlet valve assembly to the back of the machine.
  6. Use a pair of pliers to press the spring clamp holding the inlet hose to the inlet valve assembly and move the spring clamp away.
  7. Install the new water inlet valve assembly and all other parts disassembled in reverse order of the procedure above.
  8. Make sure to clean the fill hose filters, if there's any, before attaching it to the water inlet valve assembly.
Jan 20, 2010 | Kenmore Elite 45986 Front Load Washer
WHEN MACHINE IS OFF DOOR IS OPEN TO AIROUT
TWO LIKLY REASONS FOR THIS
1ST IS YOUR APPLIANCE CONNECTED INTO TRAP UNDER SINK IF SO MAKESHORE ITS NOT YOUR WASTE RUNNING BACK TO MACHINE
2ND INLET VALVE IS LEAKING-TO SOLVE THAT A NEW VALVE IS NEEDED
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cold water continues running even after washing cycle is over
I agree with HawaiiTech. If your FAV6800AW or FAV9800AW has water still flowing with the washer 120VAC power cord pulled then the inlet valve is stuck open. Because you are posting in the Neptune FAV6800AW Top Load Washer forum here is some machine specific info for the FAV6800AW or FAV9800AW TL’s. If you are going to DIY here are the links you need;
The Service Manual for reference. Sears Parts Direct for reference.
See page 35/36 to access, remove and replace the hot/cold water inlet valve.
The part number for the inlet valve is 12002242. There is a Substitution P/N 25001046 you will see that here its item 21 at Sears Parts Direct. If you DIY you may want to consider a local purchase, take your water inlet valve assembly to the parts counter and make sure the 120VAC connectors on the solenoids match up. The water inlet valve is easy to replace just follow the SM.
If your machine type is not a FAV6800AW or FAV9800AW please disregard my post.
Good luck and post back if you have questions or concerns ….Rich… aka dh1200s
Nov 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water dripping into the tub when washer is not in use
You are right, it is called the water inlet valve assembly. I will attach a photo for reference. You can try to clean the small metal screens inside the opening on the valve, but the problem is most likely in the solenoids. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity means a bad solenoid and the water inlet valve will need replaced. Sorry for your trouble and I hope this helped. Best wishes.
Sep 28, 2009 | Fisher and Paykel GWL11 Top Load Washer
Water wont stop even if i unplug i had to cut the water supply off
yea sound slike you ohave a faulty water inlet valve, stuck in open positon,removet he hoses and repace the inlet valve on hte washer.
May 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
64 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
