Question about Dryers
How do you get to the belt to change it
I need to change the belt on the drum I don't know how to get to it it maytag. DE 410 elevtric
    President:
  • 1,922 Answers
Remove front cover,then top cover, slip new belt over drum,then either from the front or rear you can string it onto motor pulley and then over idler pulley manually rotate drum to make sure belt is centered on pulleys and your done
Posted on Sep 26, 2009
Maytag washer (about 15 years old, 2 speed) starts to spin and then stops. Hot smell but the motor is fine. Is there a fuse it is tripping? Some other problem?
the belt or clutch slipping most likely if it has no belt send it to junk donate it whatever if it has a belt check it make sure no lube or water is leaking onto it make sure tensioner is keeping it snug if its just the belt change it don't use a car belt the 1 u need is called a fractional horsepower belt like a evaporative cooler belt that's an old machine too bad u don't live near me i got a good 1 for $80 bucks u can pick them up cheap in the classifieds
Apr 21, 2012 | Maytag Washing Machines
I need a diagram of how the drum belt is installed on a maytag centennial dryer. Mine came off and I don't know how to put back on.
Hi c ellerts..
Here is the picture of the routing of your Maytag..
You can get this at the following wepage
Please take time to rate me thumbs up
http://www.expertappliance.com/dryerbeltconfiguration.html
Sep 12, 2011 | Maytag Dryers
L have a older maytag lde 410 the drum is hard to turn after the belt came off can you help us please
here is a descent website, Hope it helps Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 19, 2010 | Maytag MDE8757AY Electric Dryer
How to put a belt on a Maytag DE 410 dryer
with some you have to remove the front upper and bottom panel
then lift drum off bogie wheels and move it ahead a few inches then loop it over the drum and around the belt tensioner pulley most swing up and down so thatyou can put belt on
Dec 18, 2009 | Dryers
Belt change on a Maytag DE410
Most of the time these models have screws in the back of the machine on the top lid. You'll need to get over behind the dryer to access this panel. You'll need a "star" type screwdriver (most come in a set). Remove the top lid to expose the drum. The belt will run around the drum and down around the safety cut out switch. This switch is most likely a teflon or plastic wheel that the belt loops around. After installing the belt, replace all of the screws and you're good to go!
Dec 11, 2009 | Dryers
What part number is the drum belt for a maytag electric dryer model # DE 50 Serio no. 997874 KF?
part number and demensions Dryer drum belt - Length is 87-3/4" Width is 1/4".
Part Number: AP3865318 made by FRIGIDAIRE does not come up as maytag.
Oct 09, 2009 | Dryers
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
Sep 29, 2009 | Maytag Dryers
Dryer got very hot and smelled burning..
This is usually a result of a stalling idler pulley or drum, causing a burned spot on the drum drive belt.
The situation will only worsen. The belt is best replaced before it breaks.
Items to pay attention to, when the drum drive belt is replaced, are:
(1) Clean and lube the idler pulley and drum roller shafts.
(2) Confirm that the drum glides will yield additional service life.
(3) Check motor condition and de-lint the blower housing and blower intake pathways.
Sep 07, 2009 | Maytag Dryers
My Maytag MDE308DAYW needs a new belt. Belt was
If you go from the top. The belt goes down the drum, between the drum and idler pulloy,under the idler then pull it over to the top of the motor pully and loop over it. When it comes out from under the motor pully it goes under the drum and over to the other side of the drum, and back up to the top of the drum. I hope this makes since.
Please rate solution if helpful
Aug 28, 2009 | Maytag MDE308DAYW Electric Dryer
MAYTAG DRYER LDE4914ACE BELT CHANGE
The belt goes around the pully so that the pully tension takes the slack out of the belt. Just like the serpentine belt on your car.
Nov 15, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
79 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
