Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Heater sounds like it is pop-ing and boiling - Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
  • 990 Answers
This can be a bad internal by-pass.(Inside the plumbing header) So all the water is going past the heater but it still has water pressure to start and will boil the water in the heater. this usually is more described as a banging rather than a poping. If it is just a poping it could be something much worse in the way of a bad heat exchanger. If you break down the top of the heater you will be able to see the wet on the exchanger pipes. If this is the problem depending on the age of your heater it may be time for a new heater.
Posted on Oct 05, 2009
The heater is set at 32 degrees but only blows cold air the water bottle is at the right level and the fan runs
Sounds as if your Thermostat is faulty and remaining in the closed position, pop it out, boil a kettle of water drop it into the hot water and check if it is opening.
If it does open then your problem most likely is a dirty heating system and it needs to be flushed.
Apr 28, 2015 | Fiat 500 core. heater. . a/c and heater...
Heater pops when heating on low cycle
not enough water flow the water is boiling inside heater
Apr 21, 2014 | Teledyne Laars Pool & Spa
Getting popping noise from water heater after shower
Popping sound is caused by sediment built up in bottom of tank: air bubbles get trapped when heating starts, and then they crackle, rumble etc when free.
Clean out sediment:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/pdf/How-to-descale-water-heater.pdf
The steps vary by type of water heater, gas or electric
Jun 27, 2013 | Water Heaters
MH6701XX
it is toast,replace unit
Apr 18, 2017 | Maytag Microwave Ovens
The thermal cutout pops on tank two after it shuts off. It boils then shuts off. It also turns off when taking a shower, producing cold water. I checked the ohm readings on the thermal cutout and the...
Question posted under Bosch tankless.
Question says 'tank'
Brand, model, and type heater unknown.
Elements mean electric.
'Thermal cutout pops when taking shower produces cold water' indicates tankless, since tank-type would maintain some hot water.
No error code might indicate tank-type.
Add a comment with type, brand and model number of heater for possible assistance.
Sep 24, 2012 | Bosch PowerStar AE125 AE125 Whole House...
My electrid rheem hot water heater makes a loud pop sound after using hot water to fill bath tub . Why?
The sound is the water heating through mineral buildup in the bottom of the tank...
The water gets superheated (boiling) because the mineral traps it aroung the element for too long....then it makes the noise as it percolates there....
How to Clean Hot Water Heater
heatman101
Jan 16, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Explain why there is spluttering sound when water is sprinkled on hot oil
Hello. When water is sprinkled on hot oil will sputter because the oil is at a temperature near or over 100 degrees C or 212 degrees F. This is the temperature where water boils. The sputtering that you hear is the water being boiled and creating steam. When the water boils and becomes steam, it expands extremely fast. This creates a "bubble" in the oil and the bubble "popping" makes the sputtering sound.
Dec 29, 2010 | Heating & Cooling
Loud popping noise?
its just the unit in defrost mode,the popping sound is water hitting the defrost heater and boiling away,no need to worry
May 24, 2010 | Magic Chef CTF2125 Top Freezer...
Rx8 will not start son drove it to store and when he returned car would not start. pulled starter have it checked at autozone, they said it was fine pulled Ing. and starter fuses had them check they...
Sounds like it could simply be a corroded battery terminal. Check your battery terminals and if loose, dirty or corroded, remove and clean with a heaped tablespoon of baking sod in a dipper of hot, (not boiling) water.. Then clean the inside of each terminal and the battery post (or what ever connection is used) with emery cloth or a wire brush. Check battery water, top up if necessary, re-fit terminals.Note: Remove negative first and when re-fitting terminals re-fit postive first.
Mar 25, 2010 | 2005 Mazda RX-8
Crackling and popping sounds when you heat up food
thats normal water expanding and boiling off from the microwave boiling those tiny water pockets in food... sounds like popcorn sometimes.
Cover your food with a paper towel to avoid spatter on the ceiling of the microwave when this is happening.
Sep 12, 2009 | Sharp Microwave Ovens
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
76 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
