Question about Pentair Pool & Spa
The blower works, bit no air is getting to the spa. could the line be blocked?
    Problem Solver:
  • 12 Answers
Sometimes you need to let a blower run for several minutes as it has to push out the water in the line you can put your hand over the jets to see if its pushing water ive seen it take 15 minutes befor . Yes you could possibly have a rat or somthing else in it also..If so i use a co2 tank and blow em out
Posted on Oct 08, 2009
WHAT IS THE USE OF ROTARY PUMP ,DIFFUSION PUMP AND AIR ADMIT? HOW DO THY WORK ?
im gonna assume your referring to the parts that make a spa work ,
1st theres the main pump most times there centrifugal pumps with mechanical shaft seals , this pump moves water in thru the filters and out the nozzles around pool ,most spa's have a two or more speed motor that runs this pump
2nd some spa's (not all) have a second pump usually smaller these are for the heating circuits , they are also centrifugal and use mechanical or magnetic seals these pumps also intake thru the filters and push water thru the heating elements and also the water conditioner (UV) and on some spa's its also a means to add water treatment chemicals as well
3rd and last but not least theres the blower now not all spa's have one of these , but most do , this blower blows air into the main nozzles exit ports and make the wonderfull bubbles in the spa , now some spa's don't have a blower and use a process called venturi to draw air into a nozzle as water is forced out of it , but this type of system is a bit temperamental and is difficult to keep working well ,
blower motors also have adjustable speeds to adjust the amount of bubbles in spa
Jul 19, 2015 | Pool & Spa
Air blower is not working.
hi ,the click could be the relay however are you sure the air blower is getting power , if not , try replacing the relay ...
Regards
Rob
www.gewizrepairs.co.uk
Jul 15, 2015 | Pool & Spa
Powermax 1250 low air flow
check the blower, it may need to be replaced, or you may need to replace the blower vacuum switch. you can jump the blower vac switch to test if it is the problem. if so, make sure all air lines going from the switch to the blower to ensure no cracks in the rubber tubing.
Apr 10, 2014 | Pentair Power Max Commercial Pool Heater...
RS 4 not one touch
Is there a different button that turns your cleaner on? Depending on the version you have, the aux that you have the blower attached to is the default aux for the booster pump. The auxiliaries may need to be cleared and relabeled, and the relays rewired to get the booster pump on its default relay, and the blower on one of the others.
Nov 10, 2013 | Jandy Aqualink Rs4 One Touch Control...
Toro snowblower wont start.I have a toro ccr powerlite that dosnt seem to be getting fuel from the fuel line into the carb. I took the fuel line off and fuel is getting to the carb so then i removed carb...
Reference the Toro snow blower. It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now. Hope this works for you.
Oct 21, 2011 | Toro Lawn Mower With Toro Power Tools
Haliburton canadian spa hot tub heating well but blowing cold air
Since the blower simply takes air from inside the spa cabinet and blows it into the spa, the only solution is to get a heated blower, or insulate the interior of your spa cabinet better.
Mar 23, 2011 | Pool & Spa
Hello , I have a 5yr old pool complete with Hayward Filter and a 1hp pool filter motor and 2 hp spa air injection motor connected to an air switch the in ground pool is 32K gallons. Problem is with spa air...
ALWAYS FREE.. SO IT SEEMS THAT YOUR NOT GETTING AIR, THESE BLOWERS HAVE FOAM IN THEM AND CAN ,AFTER A FEW YEARS GET CRISPY AND BREAK UP AND PLUG THE AIR PUMPS SUCTION PORT. THE FOAM IS USED AS A AIR FILTER AND A NOISE REDUCER , WHEN THESE BLOWERS GO BAD 90% OF THEM CAN'T BE REPAIRED ! = JUNK.. TO SEE IF YOU HAVE A RESTRICTION IN YOUR LINE OR LINES ,USE A SHOP VAC TO **** AND BLOW THE LINES IN AND OUT.. THESE BLOWERS ARE HELD IN USUALLY WITH ONE SCREW AND ARE EASY TO REPLACE ONE MORE CHECK 4 YA IS, THERE MIGHT BE A CHECK VALVE INLINE ON THE BLOWER , IT MAY BE BAD . BEST WAY TO CHECK IS TURN THE BLOWER ON FIRST , THEN TURN THE WATER PUMP ON.. HEY IF'N I WAS OF HELP GIVE ME A REVIEW OR A THUMB.. JAY YOUR LOCAL POOL PUMP WHISPERER IN FLORIDA
Nov 15, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Have a dreamaker X-500 Only get air on one side out of my jets. Steve
Either an air line has become disconnected, or the air valve on the spa is clogged/broke.
If this is a blower model and not a venturi tee air injection system, the lines on the one side probably blew off.
Nov 14, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Blower works and jets do not?
Water jets will not work?? Is your pump on? I would expect to open ports on the top to introduce air to the water stream. Is this the case with your unit?
May 02, 2010 | Comfort Line Spa 2 Go Portable Spa with...
The blower on my spa will not turn on
If you've made no changes to the wiring from when it worked correctly, then it can only be the switch. Get a new one, switch off the breakers, and wire it in according to the instruction that come with it.
Apr 30, 2009 | Intermatic PART - AIR SWITCH 4 FUNCTION...
Pool & Spa Logo
77 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
