Question about Dell InspironTM 1501 Notebook
Dell laptop will not accapt ac power or charge
My dell laptop will not accept ac power, and the battery does not charge. it is not the charger or battery, they work in other units. currently, the only way to use the unit is to install a charged battery from another computer.
  • 37 Answers
Hmmm, check out the port where you plug in the charger. Has the internal pin been bent or pushed in? I've seen that happen on other devices. If you have access to another charger try that ... it *may* have a slightly longer reach ... the manufacturing tolerances are tight .. but there may be a slight difference between units.
Cheers,
Ripface.
Posted on Sep 26, 2009
    Problem Solver:
  • 31 Answers
Hi
please update the latest version of BIOS
if that does not work please contact the dell technical support they will replace the ac adaptor or
  • 1 more comment
  • Manjunath78
    Manjunath78 Sep 26, 2009
    hi
    if that does not work please contact the dell technical support they will replace the ac adaptor or motherboard which
  • Manjunath78
    hi
    if that does not work please contact the dell technical support they will replace the ac adaptor or motherboard which eeve
  • Manjunath78
    hi
    if that does not work please contact the dell technical support they will replace the ac adaptor or motherboard which ever is
Red indicator blinking
does laptop work without external power supply,if no then Battery probably not charging Dell computers don't like oem power supplies as often need specific dell charger to suit model laptop so that laptop will recognise it and allow battery to charge
Aug 09, 2014 | Dell Precision M4300 Laptop AC Power...
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
When I unplug power cord laptop goes off instantly ,like there is no battery!
The charger is not charging the battery. It could be the battery is dead or the laptop motherboard has a problem that wont allow it charge the battery OR it is a DELL and you are not using a DELL factory charger
Nov 30, 2012 | Dell Inspiron 1564 Laptop AC Power Adapter...
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
Charger is plugged in but not charging but can still power the laptop, how can i get the charger to charge the laptop
Same topic on hardwareanalysis.com:
AC adapter not charging Dell laptop battery, but still works?
http://www.hardwareanalysis.com/content/topic/75751/
Source for Acer Aspire 5520 AC Adapter
May 10, 2011 | Acer Aspire 5520-5908 Notebook
When i remove my charger, the laptop turns off.
As lond as the battery is still accepting charge from the charger and will run ok on a battery, I wouldn't worry. Pulling the AC power cord isn't a good idea when the laptop is running anyway.
However, what you describe sounds like a dead battery that will no longer accept a charge. Even a battery showing 100% charged can still fail, as it drains in seconds if dead. What kills most batteries is leaving them in the laptop afetr they have charged and running on ac power.
Mar 27, 2011 | Samsung R519-53S Notebook
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
Charger not recognized
Folks.
The issue with most of the Dell charger issues rekated to a new charger not being able to charge the battery is the fact that Dell has a screwy proprietary circuit design in their laptops and chargers.
It seems that the Dell laptops are designed so
only Dell chargers will work. While other
brands of chargers will power the laptop when plugged in,
they will not charge the battery.
They do this so they have a monopoly on their chargers and thus can charge a frickin' fortune for their, Dell chargers.
Want them to change this? don't buy Dell products for a while. If enough people ban them, they would change this **** overnight!
Jul 07, 2009 | Dell Inspiron 1501 Notebook
Dell InspironTM 1501 Notebook Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
