Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Icemaker has ice in icemaker, but does not drop it and refill to make new ice. What do I do?
  • Whirlpool Master
  • 1,606 Answers
Check the coils under the refrig , to make sure they are clean . If not clean , then please clean , and wait about a day . If still no ice , replace the ice maker . An ice maker will not harvest ( dump ) , unless it is 5 degrees . Dirty coils will make a freezer temp anywhere from 10 - 18 degrees , yet food will still be frozen , but ice maker will not work .
Posted on Sep 26, 2009
3 Suggested Answers
SOURCE: Icemaker stopped working
you likely need a new icemaker (part # 2198597) i would visit the following website to help determine this fact.  http://fixitnow.com/sbrvrs/icemakers.htm
Posted on Feb 05, 2009
  • 185 Answers
SOURCE: Icemaker is making ice but it will not drop into container
Ice maker has built in heater to thraw ice alittle so the finger scooper lifts up ice and out. Be sure the ice cubes are not stuck in between fingers cause that will jam it. if you dont see any jam then replace ice maker
Posted on Mar 28, 2010
Ice maker overfills the ice tray, ejecting large block of ice instead of individual cubes.
What is your model number? Sounds like you may need a new icemaker. Sometimes when the icemaker motor goes bad it causes the icemaker to keep filling even though it hasn't kicked out the ice in there. Also, are you sure there isn't 2 valves on the refrigerator?
Nov 15, 2015 | Refrigerators
Icemaker fills and then shortly after refills what would cause this problem
generally its the thermostat in the ice maker. or module head of the ice maker. sometimes the parts of the ice maker cost as much as the whole icemaker it self , so when looking at parts get a price on a complete icemaker
Mar 08, 2014 | Sub-Zero 632 / S
Troubleshooting a GE TPX24 icemaker
a19e2387-1433-4c2d-bb46-e670a2bac700.jpgSimple if the ice maker is not filling with water after cycling then fill ice maker until full allow water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water replace the=> WR57X10051 Water Inlet Valve If the Ice Maker does nothing with ice still inside the ice cube slots then replace the=> WR30X10093 Ice Maker Assembly These ice makers are electronic and once they fail there is no replacable parts. I am here should you have questions, Thanks Sea Breeze
Jan 13, 2013 | GE WR30X10093 Refrigerator Icemaker Kit
My icemaker is not dumping the ice when it's frozen.
Replacing the icemaker is neither expensive nor hard. Order a replacement on the Internet.
Sounds like a malfunction in the icemaker itself.
May 27, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool IceMagic Plus not working.
Pour about 2/3 cup of water into the ice maker . If it dumps the ice but doesn't refill , replace the ice maker . If it doesn't dump , and the cubes stay in the ice maker , replace the ice maker .
The switch on the icemaker for normal , runs the icemaker normaly . In the ice plus , a small fan comes on , blowing the inside air , over the ice maker mold , to help it freeze faster .
Sep 14, 2009 | Refrigerators
Ice maker is not making ice. I can see no other problem and as far as I know the freezer was not left open as there is no frost buildup inside the unit. Everything is frozen, only problem is NO ICE!!
Pour about 1/2 cup of water into icemaker and see if it dumps the cubes after a few hours . If it does , and icemaker does not refill , then water valve is the problem . If the icemaker never dumps the water poured in , then icemaker is bad . ALSO , check to make sure the coils under refrig are clean of dust , lint , etc . Icemaker has to be 5 degrees to operate .
Jul 22, 2009 | Freezers
Maytag MSD2756GEW went from hollow ice to no ice. Water dispenser works fine, good pressure, new filter, etc., fill line doesn't appear frozen. Replaced water valve to icemaker. When refrigerator plugged...
I assume the water valve you replaced is the fill valve located within the refigerator.
If so, I suggest that you check the saddle needle valve on your water supply pipe - (generally in the basement). It may have finally clogged up totally from calcium deposits.
Replacing it may resolve the problem. Even if it does not, you've spent less than 10 dollars on it and you've eliminated one of the possible causes.
Jun 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Feb 05, 2009 | Whirlpool GD5SHAX Side by Side...
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Whirlpool side by side refrigerator with a new ice maker. The ice maker works fine but will not drop the ice. If I cycle the arm off/on (up/down) then it dumps the ice a few minutes later. ...
Humm thats a good one, but I will try to help you out. First off you say the icemaker is new, so does that mean you bought the icemaker and installed it on the refrigerator. Or is the refrigerator new and it has an icemaker. If you installed the icemaker new on an older refrigerator you can have a few problems. Most likely the freezer is not getting cold enough for the icemaker to cycle on its own. Especially if you are peaking in every few minutes like I would be doing. The icemaker will start a new cycle when the temperatur hits 0 degrees. If the freezer is only getting to 5 degrees the icemaker will not cycle. In that case the problem would be with the refrigerator not the icemaker. If the freezer is getting to 0 degrees then you may want to take that icemaker back and get a replacement. Good luck and I hope I helped. mca0824@aol.com
May 02, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
273 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
