Question about Pelonis Disc Furnace Heater
I have a small Truck Camper and want an electric
I have a small Truck Camper (fits over a pick up truck) and want an electric heater, that is relatively quiet. What do you recommend?
  • 999 Answers
One of those small ceramic units is compact and would do the job for a truck camper. They have fans built in and are pretty quiet. They are cheap and don't take up valuable space. I would look in a BigLots or close out type store.
Eric
Posted on Sep 26, 2009
12 volts to propane gas valve were does it com from
Propane Conversion Kits for Car, Auto, Truck, Generator ...
www.nashfuel.com/conversionkits.asp
CHEVY 350 V8 PROPANE KIT / HOLLEY 4 BARREL SMALL BLOCK INCLUDES ...DUAL FUEL PROPANE & GAS KIT 4.3 V6 TBI SONOMA S-10 S-15 BLAZER ...MODEL 100 SERIES IS A SINGLE DIAPHRAGM AIR-GAS VALVECARBURETOR/MIXER ... IMPCO JB DESCRIPTION: VAPORIZER WITH 12 VOLTFUELOCK ...
[PDF]Truck Camper Owner's Manual - Travel Lite Campers
www.travellitecampers.com/wp.../Truck-Camper-Owners-Manual.pdf
USING YOUR LP GAS SYSTEM AT LOW TEMPERATURES . ...... The detector is powered by the 12-volt DC system and is always powered as long as the camper is ...Do not block the tailpipes or situate the vehicle in a place where the exhaust ...... as familiar with your camper as you are with your own personal car or truck.
Cheap Homemade Propane Injection System For ... - YouTube
? 1:57
https://www.youtube.com/watch?v=3RAVBoYX5S0
Sep 11, 2008 - Uploaded by hammerdownauto
The best times I've got with this old truck, fuel tank, tool box and all was in the high 15's. .... The engine I'm using 60 years old and the car body is 40 years old. ... I used a generic propaneregulator and 12 volt air solenoid valve. ... just curious what you think this does to the o2 sensors as far as gas / air mix ...
[PDF]"motorized" Manual - Gulf Stream
Jan 21, 2016 | Cars & Trucks
I have an on/off switch inside the camper and outside the camper where water heater is located. does this mean i have a propane/electric water heater?
Most likely if you have a switch that just is on/off it is for powering an electric water heater. If the water heater is propane and electric there would be a selector switch to choose between the two power sources.
Feb 15, 2015 | Water Water Heaters
Just want to figure up to truck to hook up camper with lights
Take it to an automotive electrical place , It won't cost much.
It's kind of a pain to do it your self. you have to lay under the truck and probe several wires and tap into them , and get them all right.
Most larger campers will have a 7 pin connector. 12 V for charging the battery , lights , brakes and reverse if the camper hides your truck lights , electric brake (not used) , ground ,
Apr 15, 2010 | Chevrolet C1500 Cars & Trucks
I just bought a 1976 Chevy with an Open Road camper on it that goes over the cab. It seems that Open Road Campers Inc. does not exist anymore. I don't have a manual for it (the camper) and can't find...
Is it a slide in camper? and if so there should be jacks that go at the 4 corners above the truck box. you lift the camper up slightly and drive the truck out from under the camper. The jacks could have been removed and stored in the camper under a bench seet in the dinett.
Mar 22, 2010 | 1986 Volkswagen Wagon Camper
How can i get electricity inside my slide in truck camper
carry an extra altenator just in case for your truck
Mar 12, 2010 | 2003 Chevrolet Silverado 2500HD
Trying to wire my slide in camper to run off my truck and charge camper battery from truck. The camper has its own set of turn/brake and running lites and I need to hook them to the trailer lites of the...
it is not just amatter of getting power ,the brake control [elctric] runts through the trair plug as well.what is needed is to break into the traier socket harness pick up each wire with atest light so you can join into it and run the wire tp where you want it.I would have thought that the factory trailr socket would all have been in the correct places anyway
Oct 25, 2009 | 1998 Dodge Ram 1500 4WD
Need wirering diagram to hook up trailer lights and elecric break
Also try http://www.etrailer.com/faq-wiring.aspx. They have a great website with lots of info. With the tow package, there should be a plug under the dash... far left above the emerg. brake petal. The harness that plugs into it should have came with the truck, or you can order one to fit it. Did thew truck come with a 7 pin plug on the back? If not you can order one from the above mentioned site. They also have the wiring colors.
Aug 12, 2009 | 2004 Dodge Ram 1500
2001 Dodge Dakota Trailer Brake Wiring
Call dealer & ask them to run your vin# to see if it came with towing package. They shouldn't mind. If not, you'll have to wire it in yourself.
Jun 05, 2009 | 2001 Dodge Dakota
Auxiliary battery use
The extra battery is there because of the glow plugs and intake heater of the duramax. During cold weather both of these systems draw high amperage from the batteries. A single battery will function, but not as well as a pair.
Apr 08, 2009 | 2005 GMC Sierra 2500HD 4WD
Pelonis Disc Furnace Heater Logo
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
