Question about Samsung Omnia Pro B7320 Smartphone
Hi, When I lock the phone for a couple of hours and after that I press the power button again to back unlock the phone, the phone doesn't answer. Then I need to remove the battery and but it again. Can anyone help me? Thanks.
  • andrelimarib Sep 27, 2009
    I tried yesterday the hard reset, but not solve it.
    Any other option?
    Thanks,
    Andre
    President:
  • Samsung Master
  • 2,923 Answers
This is a known issues with Samsung Omnia. I've heard this problem with several Omnia users. The only thing that would resolve this issue is to have a ROM update on your phone. Please note that updating your ROM will delete all information on your device, so you will need to backup first.
What I could suggest is to contact the manufacturer and have the ROM updated to free if the phone is still under the warranty. Updating the ROM is just like updating the firmware of the phone. This should resolves the issue.
Have a great day!
Posted on Sep 28, 2009
  • Samsung Master
  • 19,396 Answers
The phone system software has a problem. Do an Hard Reset to return to flash factory settings.
Here the procedures to reset the Omnia:
1 Open the menu: Settings>System>Hard Reset
You will get the following options:
a.Main Memory - Reset
b.My Storage - Reset
c.Storage Card - Format
The phone will ask for user code to proceed:
i900 to use 1234
i910 to use last 4 digits of your mobile number
Try both, as I am not sure about the code for your model.
2- Hard Reset using keys and reset hole:
Press the reset hole beside the power button.
Press Call and Cancel Button at the same time when Samsung Omnia appears on the screen.
Reset Screen will pop up, asking "Are you sure you want to format?" You have to choose between Format or Cancel .
This hard reset will not erase the internal memory.
Another way to reset: press and hold on the CALL and END CALL buttons
use stylus to soft reset phone at the same time
3 You can also reset typing the following dial code:
*2767*3855# - this will reset without warning, erasing the internal memory
Posted on Sep 26, 2009
My Samsung GT-i9003 is locked fo pattern lock & email & password lock
  1. first press Up Volume Key on phone and hold it on lock screen.
  2. then press on the home button and hold it.
  3. Last the power button and after it starts up just release it.
  4. A menu will come up.
  5. just click on home button to select up and down in the menu.
  6. go to third option named as "DELETE ALL USER DATA".
  7. It can take up to a couple minutes.
  8. the phone will restart and the unlock pattern problem is fixed.
    *note this will reset phone to factory settings, but it will allow you to access it again.
Jun 22, 2014 | Samsung Unlocked i9003 GT-i9003 4GB Galaxy...
BEWARE OF CHINA MOBILE PHONES
We're they really serious or you might have contacted a wrong chap. We technician can unlock any phone. Your phone should be unlocked by volcano box software ver. 2.1.6 or manually by pressing volume up, power and call buttons simultaneously. Try it bob and good luck
Jun 15, 2013 | Cell Phones
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
Hello, my MW511 Fiisher and Paykel top loader washer is not working, the lid locked light keeps flashing before the spin cycle and it keeps beeping and never starts the spin cycle... what can be wrong? I...
Hi - you may have somehow put the machine into data mode - its either that or the door lock itself has malfunctioned - the only other logical one is thw controller module.
I'm assuming its a Phase 6 - try this - press/hold wash temp & power button until u get 2 beeps & lights up - release buttons...
NOW IMPORTANT - be careful you are in memory system of the controller -
1. press start/pause to unlock/lock & toggle that lid locked lights - check default is off.
2. I think its either advance or regular to turn pump on/off.
3. try a few buttons see what happens - THEN
turn off at the wall & try it again, if it still doesn't work then we may have a more sinister problem which will require correct testing of the components.
This will require a thorough knowledge of how to interpret the test results, to nail the culprit.
Sorry cannot help further...
Jun 30, 2011 | Fisher and Paykel Washing Machines
KRZR k1....
It sounds just like a keyboard lock and you need the code to unlock it. though it should be prompting you,
if you push * and # on the same time your keyboard locked. When you press it again, you unlock your keyboard
Your phone’s four-digit unlock code is
originally set to 1234
The six-digit security
code is originally set to 000000
If you forget your unlock code: At the
Enter Unlock Code prompt, try entering 1234 or the
last four digits of your phone number. If that
doesn’t work, press s and enter your
six-digit security code instead.
If you forget other codes: If you forget your
security code, SIM PIN code, PIN2 code, or
call barring password, contact your service
provider.
hope any of this helps .
Feb 02, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
DVD/VCR Locked
My DVD/VCR Daewoo locked and everytime i pressed a button it just said LOCK! I plugged off the vcr for a few hours and then plugged it back in and pressed the on button. Now im watching the dvd that was stuck inside. Try it, you just never know.
Nov 19, 2007 | Daewoo DVRS04 DVD Recorder/VCR
Phone got wet and now the keys are all screwy.
spray the phone with q20 its a water displacement spray
Jul 12, 2007 | Sony Ericsson W550i Cellular Phone
My dvd/cd try does not open when i press the eject button say "locked"
That means your trays are on Child Lock (this is a safety feature to prevent any accidental opening or closing of disc trays by small children when listening to your favorite tracks.)
To solve this, simply switch off your radio to Standby and hold the power button...whilst holding the power button, press open on the tray that is locked....the system will display UNLOCKED on the display of your hi-fi.
That should be it. To lock the tray....repeat the same process on the particular tray u want locked.
May 21, 2007 | JVC DX-T9 System
Samsung Omnia Pro B7320 Smartphone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
