Question about Coleman Air Tools & Compressors
Motor trips breaker
At around 60 lbs. my Coleman Balck Max's motor will speed up and slow down constantly until the motor gets so hot the breaker trips.
  • 5,603 Answers
The speed is going below where the starting winding cuts back in. That will wreck the motor in short time! The current will shoot up a factor of at least three when the start winding activates.
Investigate why the load is excessive on the motor. Is the motor undersized or is the compressor have a problem? Low oil and bearings seizing?
Posted on Sep 26, 2009
    President:
  • 1,015 Answers
As the pressure in the compressor increases...so does the demand on the motor. It sounds like the motor is worn out. It could be the bearings or the windings. You could remove the motor and have it re-built(new bearings and windings) at an electrical shop or try to find a replacement on line. If the motor does not have sealed bearings you could try re-packing them with grease or oil. Most motors now have sealed bearings and when they wear out the motor will need them replaced. Check to see if the motor is still under warranty before having it repaired. Sometimes the motor will have a much longer warranty then the rest of the compressor and you may get the manufacturer to send you a new one.
Coleman mach rv ac unit tripping breaker
If it trips the circuit breaker as soon as you turn the FAN on, suspect either a bad fan motor or a failed fan motor start capacitor. If you are able to turn the fan on but the circuit breaker trips as soon as the COMPRESSOR starts, it is possible that the compressor is seized.
If, on the other hand, the unit is tripping a GFCI (Ground Fault Circuit Interrupter) breaker or GFCI utility outlet, it is possible that neutral and hot are reversed at the outlet into which the trailer is plugged (happened to me this year at an RV park).
May 14, 2015 | Coleman Heating & Cooling
My lights dim and microwave fan slows when turning on toaster
ABSOLUTE FIRE DANGER
Do NOT keep overloading circuit until electric is brought up to code.
Voltage drop.
Your breaker is rated more amps than the wire ... so wire is getting hot ... and appliances are starved for power.
The breaker should trip, but somebody has put in larger breaker without installing larger wire.
So wire is getting hot as appliances draw more power than wire can safely carry ... but the breaker should trip when wire gets hot ... but breaker is not tripping because it is oversized.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Microwave should be on dedicated 20 amp circuit ... which means 1 breaker supplies voltage to microwave and nothing else. This is code today.
Mar 21, 2013 | Home
How to adjust a fuel governor for a 3750 watt coleman generator
With parts list in hand, look at reference #21 governor arm and reference 89/90 adjustment screw. This adjustment will increase decrease engine speed. I would use a meter with hz setting to set engine speed to achieve 60 cycles. Sixty cycles on the meter would indicate that the engine is turning 3600 rpm which is max. If all working correctly, voltage should be around 120v at 3600 rpm and 60 cycles. Good luck
Aug 02, 2011 | Coleman Powermate Proforce 6,000 Watt 12...
A FRIEND OF MINE HAS A T103 TIMER FOR HIS OUTDOOR SIGN. I RECENTLY INSTALED A NEW CLOCK MECHANISM, HOWEVER IT WILL NOT KEEP CORRECT TIME TO TURN THE SIGN ON OR OFF AT THE PRESET TIMES. IS THERE A WAY TO...
1) There is no speed adjustment on timer clock motors.
They are manufactured for 60 Hz, which is the controlling factor for motor speed.
60 is the number of cycles per second that AC electricity oscillates, caused by a turbine spinning inside magnetic field at power plant. This speed is very constant, and so clock motors keep correct time for years or decades.
2) A loose wire or loose circuit breaker could cause motor to lose power at times.
Clock would appear to run slow.
Check terminals. Make sure no insulation is sitting under the screw-down plate on timer terminals.
Tighten wires very tight against copper wire.
Move Hot wire to another circuit breaker and see if problem persists.
Tighten screw on neutral wire on neutral busbar inside breaker box.
3) Problem could also be bad clock motor for some reason.
For $16 replace T100 series 125Volt clock motor
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
4) Trippers contact a lever, make sure lever has bit of grease so trippers are not hanging on the lever. Off tripper moves lever one direction, ON tripper moves lever other direction.
Double check operation of lever by moving override back and forth.
Override should snap crisp and clean, and not be extraordinarily hard to move.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 05, 2011 | Intermatic T103 Indoor 120-Volt 40-amp...
I have a 3phase electric motor 440 v amps.7.6 and drive thats 440
Allowing for start up current I would put a 16amp 3 phase breaker/trip in circuit. If this trips then use a 20amp.
Aug 01, 2010 | Heating & Cooling
House circuit breaker trips when machine is set to delicate wash
Motor controller or motor itself has a short.
OR something stuck in the pump impeller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 22422 Top Load Washer
Delta Radial arm saw 33-990 tripping circuit breaker
More than likely motor but try this , if you have a wrap around amp probe or can borrow one or purchase a cheap one place the amp probe around the positive wire connected to panel breaker ,with meter on proper scale ,start saw and read probe current , if cap bad current will be high and stay until breaker trips , if motor will start high on start ,then low then ,very high and breaker will trip , be careful in panel working around live circuits , the reason it reads this way is because as the motor warms the laminates it the armature separate and cause the increase in current to spike ,if cap bad never gets to speed and has high current draw constantly , to verify cap(1) remove from circuit (2)place a screw driver across terminals to release any charge (3), then take ohm meter on ohms place meter leads on terminals one on each terminal at same time meter will rise and fall back(4) reverse leads and should rise and fall as before if it does this it is more than likely good a lot of electrical reasons for this but this will tell you what you wanted to know , good luck
Dec 08, 2008 | Saws
Electrical - Air Conditioning
Ben, you are on the right track. To upgrade the breaker, first look at the main house breaker panel and determine if allowing more current through main breaker will be taxing it too highly (will 20 more amps exceed my main breaker limit...what is the main breaker current trip at?) Then look at the wire size leading away from the 40 amp breaker to outside. If it is 6 gage copper or 4 gage copper-clad aluminum wire, you are ok to upgrade. Any smaller wire size could be unhealthy.
Sep 03, 2007 | Heating & Cooling
Air Tools & Compressors Logo
194 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
