Question about HP DeskJet 940c InkJet Printer
I have cleaned the heads, the ink cartridge is new, but blue will not print. Any advice?
SOURCE: Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Posted on Oct 13, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
SOURCE: HP L7680 Print Head Problem
I do have the same problem. When i checked the printheads, i came to know that electrical circuit was damaged. Do one thing. Clean copper contacts of both printheads with a soft cloth . And try one more time. another solution is just bur new ones
Posted on Nov 11, 2008
  • 5 Answers
SOURCE: Blank Ink not pumping to print head
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Posted on Nov 28, 2008
mace1mace
  • 1138 Answers
SOURCE: black ink cartridge not printing
Hi!
From what you did you could have missed something... here's a link.. try to access the link and remember the procedures for the control panel of your printer and to the printer software installed on your computer..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01643376&cc=us&lc=en&dlc=en&product=3795406
Much appreciated if you rate this help...thanks..
Posted on May 23, 2010
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
My HP 6500 won't print blue. New ink cartridge installed, heads aligned, and cleaned. Still no blue. Any ideas.
Print test page in the software, if no blue try print head clean again, if no go return cartridge for replacement.
Is it genuine or refilled??
Jan 13, 2010 | HP Officejet 6500 Wireless All-in-One...
Started printing light / dark blue bands instead of same shade. Tried cleaning but no different. Thanks.
Do a proper head clean.
Remove the cartridges and put them aside.
Remove Print head taking care not to touch the metal parts.
Boil some water, pour one quarter inch of boiling water into saucer.
Place the part of the print head where the ink comes out in the water.
Give it a few seconds, you will see the ink coming out into the water.
Sit the print head on some paper towel with the part where the ink comes out on the towel and let the excess water be absorbed by towel..
Replace print head in printer, taking care not to touch the metal parts.
Place cartridges back in print head.
Do some test runs to check the condition of the head, you may have to do a head clean or two.....
If that doesn't work try a new blue cartridge.
Usually works on my machine.
Jul 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
Blue ink - printing problem
Your Cyan cartridge is empty and need replacement. Maybe you can clean head of Cyan cartridge with alcohol but symptoms are the empty cartridge!
Good luck.
Sep 11, 2008 | Canon PIXMA MP830 All-In-One InkJet...
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP940C doesn't print the blue ink
Hi, the printer need nozzle check you can determine what are the problem ink cartridge. , if blue does not display in nozzle check printer need head cleaning twice.
Feb 03, 2008 | HP DeskJet 940c InkJet Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
HP DeskJet 940c InkJet Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
