Question about Bosch HMT9626GB Microwave Oven
Mircoave doesnt trun on
I have a bosch HMT9626GB microwave. It doens't turn on. What is the first thing I shoulkd check?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Check if you are getting power to the microwave by checking the plug, and the fuses in the plug.
Posted on Dec 18, 2007
Bosch microwave bulb
If there's no obvious cover or customer-accessible socket (and the owner's manual doesn't cover it), the manufacturer would prefer so.
It means that the whole outer cover or other panels would have to be removed to access the bulb or bulb assembly. In a bulb assembly, both the socket and bulb are replaced as one unit.
Jun 06, 2013 | Bosch HMT9626GB Microwave Oven
Stops working after 20 seconds
The magnetron is over heating causing the thermal fuse to open to cut power, the only option is replace the part, but keep in mind it is the most expensive item to install.
May 07, 2012 | Bosch HMT9626GB Microwave Oven
Microwave starts to work then cuts out after a problem I had.
MICROWAVE RUNS ABOUT 5 SECONDS AND SHUTS OFF AND SMOKE FROM UNDERNEATH CABINET
Apr 15, 2010 | Bosch HMT9626GB Microwave Oven
When i opened the microwave door the power went off. Main fuse seems to be ok
if you close the door, hit start, and it continues to work, then it's doing what it's supposed to do! safety feature!
if it 'pops' a breaker, then there may be a problem with the 'safety interlock' switch, which is engaged when you close the door! possibly cause an electrical "short' when you open it. then you need to get switch replaced!
contact a qualified repair person, or check if your warranty is still covered, and have retailer, or manufacturer rep. fix it! if it is a switch problem it may cost less to replace the microwave!! do the math!
good luck!
Oct 19, 2009 | Bosch HMT9626GB Microwave Oven
How to set the timer? No manual
One of the manuals on this page may help.
If not, select the customer care link to the left to order one.
Jan 27, 2009 | Bosch HMT9626GB Microwave Oven
How to replace both door hooks on BOSCH MICROWAVE/GRILL
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 23, 2008 | Bosch HMT9626GB Microwave Oven
Bosch HMT9626GB / HMT9 / 0B 1000 Watts...
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
Sep 15, 2008 | Bosch HMT9626GB Microwave Oven
Signs of burning on inside of plastic door surround .
replace plastic inner and check any rust is there, check inside body and compleat door.
Nov 12, 2007 | Bosch HMT9626GB Microwave Oven
Repairing Sansung Microwave version CM 1029
first check voltage to hv transformer if volts probably loose contacts on magnetron ,cap ,diode if still change magnetron
Mar 18, 2007 | Bosch HMT9626GB Microwave Oven
Bosch hmt9626 gb 1000w microwave cuts out after 20secs
ur mag netron is faulty the reason for cutting out is thermal cutout switch change magnetron
Jan 20, 2007 | Bosch HMT9626GB Microwave Oven
Bosch HMT9626GB Microwave Oven Logo
181 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
