Question about Goulds Pumps Goulds 1/3 Hp 115V 1 Phase Sump Pump 3/8" Solids
Removal of impeller and screw - is it clockwise or counter clock wise Goulds Jet pump Model JB05 For Shallow wells
  • 523 Answers
The attached may be able to assit you.
http://www.goulds.com/pdf/7381.pdf
Tom
Posted on Oct 03, 2009
I have a pump at cabin it pumps water but won t build up pressure and shut off got this pump 7 years first problem
Normally there is a pressure TANK, used in conjunction with a Booster pump. Do you have one on this system? That's where the pressure is stored. If no pressure, the bladder is either failing or has failed.
Mar 07, 2015 | Goulds Pumps Goulds 1 Shallow Well Jet...
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Why dont i have water pressure after my pump cycles off
Make sure your tank is well pressurized and not water logged.Is there a significant difference between your cut in and cut off pressure.Check for leaks -water or air.
Sep 07, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Why cant i talk to an expert
We're blocked by agreement from talking directly to viewers.
We're drones... but you can submit lots of questions, videos, and images for expert to review problem and offer possible solution... sometimes very quickly depending on specifity of question asked.
May 20, 2013 | Goulds Pumps Goulds 1 Shallow Well Jet...
Impeller
J5s is a back pull out. Remove the bolts holding the front casing to the motor. Remove the diffuser. The impeller will either be screwed on. ie the impeller is moulded with a thread, or key wayed .ie a separate metal nut holds down the Noryl impeller and a small piece of "key" steel keeps the impeller on the shaft.
Remove the rear fan cover, and either use a flat screw driver (if there is a slot in the rear of the shaft) or a shifter (if the shaft has a hex) or you may have to prise the fan off. to get a good hold of the shaft.
Hold the rear of the shaft, and with the correct socket undo the hex on the impeller. either the nut or the whole impeller will come off. If just the nut type. Use cable ties to thread down the centre of the impeller to the out side and join. do this in a couple of places.Use these as a lever point to pull off the impeller.
The seal just pulls off. there is two parts stationary and rotating.( 18th may, yourve probably worked it out by now)
May 18, 2013 | Goulds Pumps Goulds J5S Jet Pump Shallow...
My water pump when reaches 40psi clicks on and off contineously
Pull the pump and check for blockage holding the foot valve open allowing the pressure to leak past the impellor back in to the water table. Sand --rocks are sucked up during the pump operation and will hold the ball off the seat.
Jan 27, 2013 | Goulds Pumps Goulds 1 Shallow Well Jet...
How do I change the motor side casing on a j5s pump
The motor must be dismantled as well . a bit scary , but I have done one Carefull not to damage the motor axle ie comutator etc.
May 01, 2012 | Goulds Pumps Goulds 1 Shallow Well Jet...
Goulds Pumps Goulds 1/3 Hp 115V 1 Phase Sump Pump 3/8" Solids Logo
1,450 people viewed this question
Top Goulds Pumps Tools & Hardware - Others Experts
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
micky dee
Are you a Goulds Pumps Tool and Hardware - Other Expert? Answer questions, earn points and help others
