Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Need a motor. were can I buy. motor is frozen (robo kleen)
  • 201 Answers
If it drives but does not pick up anything
then thats the motor with the prop, water gets in it
but there are two screws with metal plate on back of motor
and a round plug then a green plug to let the water from your pool out
Posted on Jun 09, 2013
SOURCE: robo kleen stopped working, motor starts but it does not move
Hello, I think I had the same problem with mine : the filterpump worked, but robot didn't move. I opened it up and the problem seemed to be that the pin which locks up the gear wheel to the axle of the front wheels had broken into three pieces. We inserted a new pin (nail, screw etc) and the Robo kleen works just fine again. Maybe you should check this is also the problemwith yours. Good luck !
Posted on Jul 11, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Robo Kleen moves but does not clean
If you can, connect it to the back wash of your pool fiter pump. Just for a few secondds that usually works well.
Posted on Aug 17, 2009
jharwell668
  • 640 Answers
SOURCE: robo kleen wont back up
Since I can't see your unit, lets go over some basic trouble shooting for this particular type of swimming pool cleaner. If your cord is tangles, you might want to start by straightening it out. If you lay it out in the sun for a few hours, it will be much easier to work with. Make sure that you do not have hair or other substances caught in your impeller. Make sure that there are not leaves or debris caught in the axle bearings on the wheels. I bet one of these adjustments is going to correct your problem.
Posted on May 19, 2010
thepatioman
  • 52 Answers
SOURCE: My Robo kleen stop working at the end of last
Sounds like you have found the problem. Change the Black Pack. Not sure the pack is available as a seperate part. Suggest you contact Robo Kleen for that info. http://74.84.137.218/website/manuals/RK01A.pdf
The Pool Tech
Posted on Jul 10, 2010
SOURCE: My Robo Kleen motor is running but the wheels do
There is a plastic gear in the drive motor that has a pin that goes through it and the drive shaft, this pin actually wears a slot in it from going back and forth and stops driving the unit.
You can probably hear the driver motor cycling forward and reverse.
i have photos of a modification to fix this
Posted on Aug 06, 2010
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
My Robo Kleen motor runs but the wheels won't turn
if motor that runs is it the pump ? is drive motor running check belts or drive system inside
Aug 22, 2011 | Smartpool Dolphin Robo - Kleen Above...
Need replacement motor. Two years old motor shot
The only place that you can buy a replacement motor for these automatic pool cleaners is directly from Dolphin.
May 31, 2010 | Smartpool Dolphin Robo - Kleen Above...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
193 people viewed this question
Top Smartpool Pool & Spa Experts
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
