Question about Cobra 148 GTL 120-Channels Base CB Radio
Huge static busts
A while ago my Cobra 148 was borrowed and wrecked. From what hes told me he reversed the polarity "by accident" im just wondering if there is a dummy diode or other saftey features to stop perminent damage. Cheers. Dan
  • 126 Answers
Like Benimur said, most all newer units have a protection diode that is there for the purpose of protecting the radio when the power cord is pluged in backwards. It doesn't take much to fix them, only a $.02 diode. Most cb shops only charge between $10 to $15 to repair them.
Rollin CBs
Mt. Vernon, TX
Posted on Jan 23, 2008
    Brigadier General:
  • 6,966 Answers
Most if not all CB radios have a reverse protection diode soldered immediately right after the power connector. Its purpose is to provide a practical short if the wires are connected wrongly to a power source. This would cause the fuse to blow. The diode normally goes bad after a reversed polarity connection and therefore would need to be replaced. This diode is not in series with the B+ line but connected parallel to the power.
In some instances, other components would also fail: Power capacitors, Audio IC, TX finals and/or the switching/regulator IC.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Posted on Dec 17, 2007
  • Louie  Role
    Louie Role Dec 23, 2007
    Hi again,
    How's the Cobra, any development(s)?
No non at all. Think im gonna have to send it off to be honest. If the protection diode had blown i dont think i'd get any life from it at all. Thanks for all your help though. Great site!
Posted on Dec 23, 2007
Have a cobra 148 boughtat local market d expect much told it was a fm rig so i have recieve i have a reverse tx key it is uniace mic 4 pin a question of reversing tx pins in mic many thanx martyn
Go to go to radios and schematics then go to C look for Cobra look for 148 then from there get the mike wiring diagram and you should be in business.
Nov 23, 2016 | Cobra Radio Communications
No noise static nothing
does it light up the front panel? If not did you accidently touch something that created an overload that may have caused the reverse polarity diode to blow?
Mar 01, 2014 | Radio Shack Powered ON TRC-444 40- Channel...
Cobra 148 gtl-st wont transmit but receives great
Check first your microphone
• check if TX is engaging when PTT is pushed.
• check for continuity ( mic and cable )
If you have not done these steps,
try it first, or borrow other compatible mic for Cobra 148GTL
from your friends on air.
Jul 28, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
My cobra 148 work well on am but not on lsb
clipping the limiter should not have prevented tx on sideband are u sure u didn't do something more accidently. r 131 is the correct limiter for the 148. just out of curiosity what year 148 is it?
Jun 15, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Power issue no power
change the reverse polarity diode.
May 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Want to disconnect the bleep altogether on my cobra 148 gtldx
If this is a stock cobra 148 gtl 40 channel am plus side band, they don't to my knowledge come with a built in r beep. Some roger beeps are instaleed through the transmit circuit on the mic, so if not in the know Don't try to fix it.Some microphones have a beep built in. I used to install beeps on these radios using the pa/cb switch to turn them on. also try the nb switch or the swr/rf switch.
Feb 04, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
122 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
