Question about Canon EOS-AE-1 35mm SLR Camera
The shutter wont work and the light meter doesn't move, also it wont advance the film. what could be wrong? I'm hoping it's the battery...
    President:
  • 1,564 Answers
There is a large circular cover on the bottom of the camera. Inside is a button battery. Yours is dead and should be replaced with one of the same I.D.number.
Posted on Sep 26, 2009
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery...
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Apr 16, 2017 | Olympus OM-4TI 35mm SLR Camera
My film advance seems to be stuck. I took the film out of the camera and it still will not move. Does this have anything to do with the battery?
No, the only thing that the FE uses the battery for is the light meter and shutter. You can operate it completely without the battery using the M90 and BULB shutter speed settings.
Your film advance problem is a mechanical problem - check for any small objects that may be jammed into the film transport mechanism. If nothing is obviously causing a blockage, then the camera will need to be serviced.
Nov 14, 2010 | Nikon FE 35mm SLR Camera
FILM ADVANCE/SHUTTER STUCK
Start simple and go from there.
I don't know if you have film in the camera so I'll read the following and choose what works for you.
I will assume the battery is working if applicable.
As stupid as this sounds press the shutter release button. If the shutter is cocked it will hold the advance. I've had people come in with this problem.
Not it?
If the film rewind has been pressed in it will disengage the film advance and stop the shutter mechanism as a result. Open the camera and close the back again resets the release.
If there is film in the camera remove it.
It there are important photos on the film and your rewind is not working use a coat to make a light proof black box. Just turn the sleeves inside out and put the camera in the coat. Wrap it so as it is closed to light. Open the camera remove the film and roll the film back in by hand.
OK so now we have a camera open with no film in it.
Open the back and look just below the shutter. On one side will be a very small "lever". This tells the camera that the film has been advanced and the shutter is cocked. Gently move the lever to the right. It should click. Now try pressing the shutter release.
Note that without film in the camera some cameras will not advance the shutter.
It should clear the problem.
If not something physical in jamming.
The film advance system could be jamming. On the side the film advance is on there will be a plastic "gear" inside the camera. Try moving by hand it should turn. You can reset the shutter this way.
Give this a try.
Hope this is helpful, if it gives you some direction please rate this answer.
Thanks
Mar 14, 2010 | Photography
Film wont advance
Metering lights are the LEDs that light up in the viewfinder. Camera on, look in the viewfinder to the right side you will see some lights. As long as these lights come on, P, M, A, *, ^ ,- You have put the batteries in correctly, and they have juice. Otherwise, you got the wrong batteries or put them in backwards.
The Minolta X-series (X-300/370, X-570, X-700) were known for this issue. Two capacitors under the top and bottom covers go bad over time. They prevent the shutter from releasing, so you cannot wind to re-**** the shutter. If you're handy at these things, you can buy the caps, remove the covers, solder in the new caps, and be fine. This issue is well known and you can find instructions on the web. Or you can send it in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at $58 incl return postage. Look him up on the web.
Sep 29, 2009 | Minolta X-700 35mm SLR Camera
Just purchased from an auction. the film advance
The first to check is the battery condition. Press the battery check button on the top cover and see where the meter needle rests in the VF. If the needle is above 5.6, battery is getting weak and it will cause irratic shutter release or no release. It's time to change the battery. If needle is below 5.6, then you have magnet problem or other fault. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 31, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film advance lever wont move. Shutter button does not register.
the self timer may be the issue. the self timer if not all the way released will not allow you to advance to the next frame :( i sometimes have to push it back to the start position
Nov 13, 2008 | Photography
Film = no light meter
jackson rook,
the speed of the film may be to high if your camera has dx coding contacts in the film chamber. otherwise---- film in camera or not it has no effect on meter operation. move the advance lever to the right slightly and push down on the shutter release button slightly to turn meter on.
Sep 10, 2008 | Vivitar V4000 50MM 35mm SLR Camera
Sears ks super camera.
You'll have to remove the bottom cover. Either the mirror box or the shutter are stuck. re-cocking it is possible by moving the wind stop clear of the bottom portion of the film advance shaft.
Aug 20, 2008 | Ricoh KR-5 SUPER II 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
159 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
