Question about Kitchen Ranges
Suddenly little power, light won't come on - Kitchen Ranges
  • 19,396 Answers
Start first tripping circuit breaker or unplugging the power cord for two minutes. Being a no power problem, this may not fix the fault.
Many kitchen ranges have a thermal fuse that can be checked.
If that is OK, then the wiring to timer control must be tested.
To be more precise I will need the appliance model number, as printed on service tag.
Posted on Sep 26, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the pilot light is out and the gas isn't on relight the pilot light on. If the pilot port is clogged and the oven range is in a drafty place then use a small wire to clean the port and prevent drafts near it.
If still the problem persists, then the igniter might have been burnt during the self clean. Please check the power to igniter while using bake mode. It should be 120 volts. If power is there and igniter is not coming on then it is bad. Please also check resistance of igniter with an ohm meter. The temperature sensor might also have been burnt. You can check the resistance on the sensor from the board. Now, if the igniter is coming on and oven is not lighting, the igniter could have become too weak. In this case you would need to replace the igniter.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Why won't it run
have you checked the relay between the battery and the starter?
i had a ltd 2 that suddenly refused to start after trying everything else it turned out to be a little black box(relay) on the fender well between battery and everything else!
May 08, 2013 | Cars & Trucks
My 95 sierra dies and won't start. no lights on dash then suddenly lights come on and truck will start. please help.
first check the connections at the battery. make sure there is no corrosion between the cable end and the battery.
When you say it wont start can you hear the starter cranking the engine over or is the vehicle completely dead?
If its completely dead I would check for power to the ignition switch. if there is power than I would check for power out of the switch. If there is no power than possible the ignition switch is failing.
I might be able to get you some wiring info if needed. just let me know.
Apr 02, 2013 | 1995 GMC Sierra
My little green power light won't come on
The freezer still works , correct.? The light could be either burned out or one of wires leading to it is loose.
Feb 01, 2013 | Danby DCF550W1 Chest Freezer
I have a 1998 4wd automatic toyota 4runner and it won't start. The engine turns but won't "ignite" the engine light and A/T oil temp light appear on dashboard. any suggestions on what to check
Hi Nikki, What oil was low? Was it engine oil or gear box oil? Did the engine overheat? what exactly happened? Did you hear any strange noises when the engine stopped? Was the vehicle towed or was it on the back of a recovery vehicle? If it was towed, at what speed and over what distance? What engine is fitted? Is it petrol or diesel powered? Give as many details as possible to help us help you. Regards John
Dec 22, 2012 | 1998 Toyota 4Runner
The TV won't turn on. The little light by the power button doesn't even come on
Blown fuse caused by a shorted power supply. Relacing the power supply board should solve the issue in most cases. You can get a power supply board from www.tvrepairworld.com
Oct 27, 2012 | Polaroid LCD-1700 17 in. Television
Laptop lost battery back-up suddenly.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 06, 2012 | Acer Aspire 5810T-8060 Notebook
2007 jeep liberty suddenly won't start after
Try starting in neutral. Gear sensor may be heating up and not registering park.
Mar 03, 2012 | 2007 Jeep Liberty Sport
I have a Honda super quiet 6300i generator. It runs fine and then suddenly will stop. It restarts fine and there are no warning lights of any kind lit on the generator. What could be the cause and how...
Check the oil. Many of these units have a safety switch that will shut off the unit if the oil is low. It doesn't take much on some of these. Or, just add a little oil and give it a try, it certainly won't hurt it.
Jul 09, 2011 | Honda Electrical Supplies
NO power in subwoofer, power light will suddenly not turn on.
I got the same problem yesterday. I just unplugged the power from the subwoofer, then plugged today. Now the lights stayed a little longer then yesterday, but goes out again a little later. So I just unplugged and wait ultil tomorrow then I'll try again.
Jan 14, 2010 | Creative Labs MegaWorks THX 550 Computer...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
