Question about GE GSS25SGRSS Side by Side Refrigerator
What is the fix for water line freezing up in door of GE side by side ?
  • GE Master
  • 1,606 Answers
WR49X10173 is the part number for the dispensor heater .I have not seen one yet , nor have I ordered one for stock . Only recently heard about this . Hopefully , instructions come with the part . I read where it takes 24 hrs to work , after being installed .
Posted on Sep 26, 2009
In the automated side for ice and water serving, the water function does not work, when i press the switch for the water to be released, nothing happens. im wondering if this problem is common and the...
Yes, it is a fairly common problem. The water line has been known to freeze, thus keeping it from flowing normally. Two solutions appear to be 1). having a very small heating unit installed which keeps the line from freezing or 2) GE has been replacing some of the doors to fix the issue.
The heater solution is approximately $125 when done by a GE tech.
There are numerous discussions online about the problem. Here is a link to one of them.
http://www.askmehelpdesk.com/appliances/ge-refrigerator-water-dispenser-160302.html
Apr 18, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE refrigerator with water and ice through the door. the water through the door has stopped working. the ice cube section is functioning.
A common fault on some GE models is that the water line freezes where it passes through the freezer. The fix is to leave the lamp for the water dispenser on overnight, or defrost the unit manually.
Sometimes you can fix this with a hairdryer, but this can cause fire/melted plastic/electrocution issues.
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water line freeze up
GE makes a water line heater to correct this design fault.They are available at most part houses
Oct 06, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE Profile Series - Side by Side Refrig - No Water Dispensing
Tubing/resevoir is coiled behind the crispers and can freeze.
Eric
Jun 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water from door dispenser
BAD WATER VALVE OR CHECK FOR CLOGGED FILTER
Jun 18, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
GE side by side with ice and water in door
This is a problem with my GE side by side also. It only happens occassionally and there doesn't seem to be any fix. I've had GE repair service here more than once. It seems that the insulation in the door is insufficient to keep the water line from freezing up. Small wonder GE is part of this awful financial mess.
Dec 17, 2008 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
the water line is frozen inside the door. very common ge problem. you can defrost the dispenser area with a hair dryer. it takes about 30 min to do. it will freeze up again. if the frig is less than 3 years old, even though it out of warranty you can argue with ge and youll get a new door to fix the problem
Nov 26, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
GE GSS25SGRSS Side by Side Refrigerator Logo
327 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
