Question about AnexTek SP-230 Pocket PC
Battery fast discharge
My SP230 battery ,even after fully charging ,gets discharged very fast,it hardly helps with 4 - 5 calls.
  • 13,433 Answers
Battery is probably at the end of its life or then there is a problem with the motherboard causeing it to consume greater amounts of power, only solution to that would be to replace the motherboard.
try with a difrent battery?
Posted on Mar 28, 2008
Lithium ion battery does not last as long
There is no such thing as a memory system in your battery. If you charge the battery until the green light on the charger comes on, that is as much as the battery can/will safely charge to. With Lithium batteries, they will fully charge whether they are at 75%, 50% or 10% capacity when placed on the charger and discharge to 0% if you use them that long. If you need the battery before the green light comes on and you use it, it will still fully charge when replaced on the charger. All batteries do discharge at different rates. Most not noticeably but a few will discharge fast enought to be noticable. If it affects your usage of the tool, you may want to exchange it or get it replaced under warranty because it will only get worse with age.
Mar 03, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
NOKIA 5233 BATTERY HEAT UP AND FAST DISCHARGE ON STANDBY
you can replace new battery for the moment and charging again. so if your mobile getting heat again may be short circuit on your mobile phone
Feb 03, 2012 | Nokia 5233 Cell Phone
My dsi will only sometimes turn on even when fully charged
Hello
This would be an indication of a bad battery.Battery will charge but when in use it will discharge too fast.
Jun 27, 2011 | Nintendo DSi Black Console
I purchase s10-3 netbook. i had problem with its battery which only runs 2 hours if it is fully charged. please assist!
How long have you been using the netbook? If it's brand new, then your battery life is too short. First of all, remember the following for ensuring that your battery performance is optimal:
1. A new battery pack must be fully charged before it is put into use.
2. A new battery pack needs to be fully charged and discharged a few times before it starts performing at full capacity.
3. Batteries discharge when left unused. If you intend to store the netbook for a while, make sure that the battery is fully charged before you do so.
4. Fully drain and fully recharge your batteries every few months.
If your netbook is new, then try one or more of the following and see how your battery performance gets affected: 1. Turn down the LCD brightness of your portable device.
2. Use built-in power management on your portable device.
3. Turn off LCD or other unnecessary accessories when not in use.
4. Set screen saver blank to 1 to 2 minutes of your netbook.
5.. Add more RAM if you can, as this will reduce the usage of the hard drive which exhausts the power quicker.
Hope this helps.
May 24, 2011 | Lenovo Computers & Internet
Battery symbol appears and then shuts off...even though it is fully charged. adapter works with other devices.
discharge battery.... connect 12v bulb from a car , to a tomtom battery.
after fully discharge, recharge again.
if no help- replace battery.
Oct 26, 2009 | Tomtom GO 720 GPS Receiver
New BN-V428U battery
BATTERY TIPS
Now a days in LITHIUM BATTERIES are used no memory effect
always charge battery for 16 hours when first use new
never keep ur battery fully discharged for long time when u store ur camera always keep it half charged or fully charged when storing for longer period
it is good to fully discharge once in a month but dont make it ur habit
pls rate me FIXYA for help
Apr 13, 2009 | JVC GR-D50 Mini DV Digital Camcorder
Battery Get Discharged within few Minutes even after Full Charge
I have the same problem, and for now an external charger is the best solution. Also try resetting 4 times. I also got a new power supply, but problem persist. Good luck!!!
jav
Nov 19, 2008 | Kaito KA1103 SW/FM/AM Radio
Battery
Before you change the battery:
  1. Charge the battery fully
  2. Discharge the battery fully
  3. Repeat steps 1 and 2
If the battery does not reset itself and start lasting longer then you do need to replace it.
Jun 26, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Rapid battery discharge/non connecting calls
take the phone and have it either reflash or the main-board replaced.
May 22, 2008 | LG CU400 Cellular Phone
Discharges very fast
it may be ur battery problem may b u replace ur battery or minimal use of display settings.,n regarding the reconizing of memory card..it may work wit some reboot method..stil check out ur battery first.....try it..if it works do rate me
Apr 06, 2008 | Motorola Mobility A1200
AnexTek SP-230 Pocket PC Logo
104 people viewed this question
Top AnexTek Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an AnexTek Computer and Internet Expert? Answer questions, earn points and help others
