Question about Husqvarna Garden
Wheel alignment needed Left front wheel not centered when right is centered. Appears to be no adjustment. How do I fix?
  • Chuck
    Chuck May 11, 2010
    Are you talking about a riding mower or a walk behind? Model Number would help when seeking advice!!
    Scholar:
  • 110 Answers
If its a rider you are referring to? You probably have some tierod adjustment where the arm that connects the 2 wheels is
Posted on Nov 01, 2009
My car was wrecked and now my front passenger tire is bent inwards
It appears your car may have a damaged or out of alignment tie-rod.
You will need to have your alignment checked and adjusted at a wheel and Tire center or mechanical workshop that conducts wheel alignments, this isn't a very costly job, my last alignment costs was around 56 dollars (they are performed when you buy a new set of tires USUALLY), but your experience may vary depending on if the rod is damaged and needs to be replaced.
Oct 21, 2012 | Cars & Trucks
How do i align a steering wheel on a 2002 astro van
If the steering wheel hasn't been removed and is just off center then the front end may need alignment to correctly get the steering wheel at center.
May 15, 2011 | 2002 Chevrolet Astro
I want to know how to fix the alignment on my 1995 honda accord ex.
Before making wheel alignment adjustment, perform the following checks:
  1. Tires should be equal in size and runout must not be excessive. Tires and wheels should be in balance, and inflated to manufacturer's specifications.
  2. Wheel bearings must be properly adjusted. Steering linkage and suspension must not have excessive looseness. Check for wear in tie rod ends and ball joints.
  3. Steering gear box must not have excessive play. Check and adjust to manufacturer's specifications.
  4. Vehicle must be at curb height with full fuel load and spare tire in vehicle. No extra load should be on vehicle.
  5. Vehicle must be level with floor and with suspension settled. Jounce front and rear of vehicle several times and allow it to settle to normal curb height.
  6. If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts.
  7. Ensure wheel lug nuts are tightened to torque specifications
Ride Height Adjustment
Before adjusting alignment, check riding height. Riding height must be checked with vehicle on level floor and tires properly inflated. Passenger and luggage compartments must be unloaded. Bounce vehicle several times, and allow suspension to settle. Visually inspect vehicle from front to rear and from side to side for signs of abnormal height.
Measure riding height. See figure. Riding height between left and right sides of vehicle should vary less than 1′ (25.4 mm). If riding height is not within specification, check suspension components and repair or replace them as necessary.
Wheel Alignment Procedures
Honda recommends using commercially available computerized 4-wheel alignment equipment. Follow equipment manufacturer instructions to obtain vehicle alignment settings. Use following procedures for necessary adjustments.
Civic Camber Adjustment
Compare camber settings with vehicle manufacturer recommendations. If camber is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck camber.
Civic Caster Adjustment
DO NOT use more than 2 shims. If more than 2 shims are required to adjust caster angle, check for bent or damaged suspension components.
Compare caster settings with vehicle manufacturer recommendations. If caster is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck caster.
Civic Toe-In Adjustment
  1. Secure steering wheel in straight-ahead position. Measure front wheel toe-in. If adjustment is needed, loosen tie rod lock nuts. Turn both tie rods equally in the same direction until front wheels are in straight-ahead position and toe-in reading is correct. Tighten tie rod lock nuts. Reposition tie rod boots if twisted.
  2. Ensure parking brake is released. Check rear wheel toe-in. If adjustment is needed, hold adjusting bolt on rear compensator arm and loosen lock nut. See figure. Adjust rear toe-in by sliding rear control arm until rear toe-in is correct. Install NEW lock nut, and tighten it while holding adjusting bolt.
Wheel Alignment Specifications
  • Camber - Measurement in degrees.
    • Front: 0 (range -1 to 1)
    • Rear: 0.33 (range -1.33 to 0.67)
  • Caster - Measurement in degrees.
    • 1.17 (range 0.17 to 2.17)
  • Toe-In - Measurement in inches (mm).
    • Front: -0 (0)
    • Rear: 0.08 (2.0)
  • Toe-In - Measurement in degrees.
    • Front: 0.00 (range - 0.16 to 0.16)
  • Toe-Out On Turns - Measurement in degrees.
    • Inner: 41.00
    • Outer: 33.50
Torque Specifications Ft. Lbs (N.m)
  • Rear Control Arm Adjusting Bolt: 48 (65)
  • Spindle Nut: 136 (185)
  • Tie Rod Lock Nut: 41 (55)
  • Wheel Lug Nuts: 80 (108)
hope this helps you out.
May 09, 2011 | 1995 Honda Accord
How do you know if you need a 4wheel or 2wheel alignment? 2000 Mercury Cougar.
Most FWD vehicles can have a four wheel alignment performed. A 2 wheel alignment is mainly for vehicles that are rear wheel drive. There are exceptions but the 2000 Mercury Cougar is a 4 wheel alignment.
Apr 19, 2011 | 2000 Mercury Cougar
Car pulls to the right. Left wheel looks straight, and right wheel looks slightly turned to the right.
this is a tow in adjustment, thats the term used by a front end mechanic, will have to be fix on a front end alignment machine, about 70-100$
Jan 15, 2011 | 1986 Chevrolet Nova
STEERING WHEEL OFF CENTER WHEN WHEELS ARE STRAIGHT NO DAMAGE OR MARKS UNDER CAR CAR DOESNOT PULL ANY WAY
Wheel alignment is probably off. Almost any garage can fix it with reasonable price (~50$).
Nov 08, 2009 | 2004 Volvo XC90
I have my 2005 Odyssey brought to Europe.Now I need to do aligment.Even Honda services don't have alignent settings.Is anyone there who could help me???
Alignment: Specifications
Alignment
Wheel Alignment
Tire size:
VAN, LX, EX, EX-L models: P235/65R16 103T
EX-L Touring model: P235-710R460A 104T
Tire pressure:
Front (VAN, LX, EX, EX-L Touring models) ........................................................................................................... 230 kPa (2.3 kgf/cm2, 33 psi)
Front (EX-L model) .................................................................................................................................................. 240 kPa (2.4 kgf/cm2, 35 psi)
Rear ........................................................................................................................................................................... 240 kPa (2.4 kgf/cm2, 35 psi)
Caster angle ................................................................................................................................................................................................... 2° 32' ± 1°
Camber angle:
Front ........................................................................................................................................................................................................ 0° 00' ± 30'
(Maximum difference between the front right and left side: 0° 30')
Rear ............................................................................................................................................................................................................. -0° 30' ± 45'
The camber angle can be adjusted up to ±25' (center of tolerance) by replacing one damper pinch bolt with the adjusting bolt. The camber angle can
be adjusted up to 50' by replacing both damper pinch bolts with the adjusting bolts.
Front toe-in ............................................................................................................................................................................. 0 ± 2 mm (0 ± 1/16 inch)
Rear toe-in ......................................................................................................................................................................... 2 ± 2 mm (1/16 ± 1/16 inch)
Turning angle
Inward wheel 41° 56' ±2°
Outward wheel 34° 32' (Reference)
Toe - 0° +/- 2mm
Sep 22, 2009 | 2005 Honda Odyssey
Crooked steering wheel on 2009 Pontiac G6, serviced twice, dealer says car is in alignment altho' the steering wheel appears pitching to left a few degrees, can this be resolved?
Yes it can be solved. All though your car may be in alignment how ever, they did not center the steering wheel prior to making any adjustments (it requires a little more work if you know what I mean), that's a part of the check list. You can fix by taken off the steering wheel but I recommend that you take it back and demand that they correct it. That's a prat of what you pay for when you taken in to get it aligned.
Sep 08, 2009 | 2009 Pontiac G6
Wheel alignment for automobile
Hello. Wheel alignment is the adjustment of the front and rear wheels so that they are correctly inline with each other and pointing straight forward. If they point to the left or right the car will pull to that side of the road while being driven. The front wheels also need to be adjusted to ensure they are not too far forward and riding on the back of the tire, or not too far back and riding on the front of the tire. Lastly, all tires need to be checked to ensure they are not leaning too far in or out of their wheelwell, causing the tires to become prematurely bald. For most vehicles it can cost you $40-$120 depending where its done, plus any shim kits needed to adjust the wheel allignment back to factory specs. Most shops provide 2 or 4 wheel alignment, so always ensure that they perform a 4 wheel alignment. Always ask for the alignment test reports for both before and after the work is performed so you can see for yourself which were out of alignment. Pot holes, curb-hopping, railroad/railway tracks, etc. play a huge part in your vehicle alignment going bad. 4 tires on some cars can cost you $500-1600 to replace, but an alignment check every 2-4 years will only cost you a very small amount, saving you time and money.
Apr 03, 2009 | 2000 Mini Cooper
Garden Logo
197 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
