Question about Westinghouse 19" Widescreen Flat Panel LCD Monitor
My monitor won't come on, the green light blinks, but nothing shows up on the screen at all. i've already changed the video card but that did not fix it. prior to changing the video card, once in a while it would show a blue screen before going blank
  • 51 Answers
Try shining a light directly on the screen to see if youve got a backlight failure, if you have there will be an image on the screen but nothing lighting it from behind thus making it seem blank, if that is not the case id start with the vga cable and work from there
Posted on Sep 26, 2009
Inspiron 1501 wont start
Does it look like it is running with the exception of the screen being black?
Does it ever post anything on the screen when you hit the power button?
Beep tones and blinking lights tells thetechnicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lightscontinuous.
Apr 06, 2012 | Dell Inspiron 1501 Laptop
Hello I have a samsung sync master 732n monitor. The power button just blinks but the monitor doesn't turn on it's properly plugged in to my computer. This has happened quit a few times already. When...
Hi your monitor is working ok but your pc display is the problem.
1.-take out the Memory and clean with eraser the gold part of the memory and your problem will be finish .
if still same means maybe your video card or board .
if your board have a video card build in take your video card and use only built in video
last press the keyboard Num Lock and look if ther is a light green
Nov 03, 2010 | Samsung Computers & Internet
My desktop monitor will blinks yellow and green, no picture
Do you have another monitor you can try. Sometimes they do go bad.
But that would be the first thing I check, make sure it's the monitor.
Sep 12, 2009 | HP Compaq FS7600 17" CRT Monitor
Viewsonic Optiquest Q20wb green blink light
It's an issue with the power supply, most likely the Capacitors (one or more) may be shot. Open it up if it is out of warrenty, look at the capacitors (they look like cans), if they are bulging at the top or even sides they are bad. This is a common problem with this monitor. Crappy Caps used in manufacturing. Replace all the caps with same rated caps and you should be good. Do your research on how to desolder the old ones off and proper installation of the new ones.
Aug 18, 2009 | Computers & Internet
Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Jun 10, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
Moniter won't turn on/power light blinks green
Yeah, I called Dell yesterday, and they said it was a problem that I could not fix myself. Whether that's true or not, I don't know, but my monitor was still under warranty, so they shipped me a replacement right away. I already got it this morning.
FYI: Their monitors carry a three year warranty.
Oct 28, 2008 | Dell E176FP 17" LCD Monitor
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Flashing Green Light on mx705 monitor
If the HP has onboard video but you have an add-on video card, remove the add-on and connect the monitor to the onboard vid. If it works you have a bad add-on video card. If it doesn't or you are already running on on-board video hook the mx705 up to a compatible HP. The older PB may be TOO old to handle it or not hve the correct drivers.
Feb 25, 2008 | HP mx705 17" CRT Monitor
Westinghouse 19" Widescreen Flat Panel LCD Monitor Logo
425 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
