Question about Garden
Intek 6.5 HP in a Craftsman 21'' mulcher/bagger --loss of power--
I've had the mower for about 5 years, mowing (mulch) a 1/2 acre yard. It fires up no problem when cold and sounds ''good''. It is hard to restart when hot though, requiring 15-20 pulls. I've tried restarting with it both on slow and wide open, with and without using the priming bulb, etc. with no difference in the difficulty of starting when warm. Main (and probably related) problem is that the mower just seems to bog down (major rpm/power loss) when cutting more than an inch of grass. To the point to where if there's even any dew, I can only cut a half swath, and even then going slowly. Engine doesn't use oil and doesn't smoke during the bog downs. Any idea if Craftsman ''detunes'' these non-user adjustable engines to make them last longer?
    Scholar:
  • 110 Answers
No - 6.5HP is enough to cut 3" at a fast walking pace. I would suspect a blown head gasket.
Posted on Oct 02, 2009
Lost my manual on my Craftsman LTS 2000 20 HP-wondering if I can mulch leaves with my lawnmower and how?
They make a mulch cover for the discharge chute and a good set of mulcher blades. You need the 9 digit model number from the label under the seat and you can get them from sears
Oct 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Ride-on hard start, loss of power
you have to get piston to top dead center, there should be 4 thousandths of clearance between rocker and valve on both valves.
use two wrenches to tighen
Sep 02, 2009 | Craftsman Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Intek engine runs poorly under load and when warm
if you have a ohv ajust valves and you might have to rebuild carb.
Jul 18, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
How many HP?
* If your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
B & D mulcher mower stop while mowing
electric & battery operation mower are not suppose to be use when grass are too long & wet, it draws lot of power that appear to runs slow.when you see try to restart i think the brake is trying to kick in.
Jun 15, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
380 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
