Question about Hoover Tempo Widepath Upright Vacuum - Blue
My vacuum has no suction and does appear to be clogged.
  • 294 Answers
Make sure the door is on securely. check that the hose is installed in the correct place on the vacuum for the floor cleaning.
Posted on Oct 11, 2009
Low suction and shuts off in upright position hose has no suction
You probably have something clogging the hose
Jan 26, 2014 | Vacuums
No suction from canister on electrolux guardian model c154e. green light on switch is on
Have you remove the hose and checked the suction at the intake of the vacuum? If the motor is running there will be suction.
If there's suction here, attach the hose to the vacuum, turn it on, and check the end of the hose for suction. If there is none or very little, there's a clog or bad leak in the hose. The easiest way to check for a clog is to drop a coin in one end, lift that end up allowing the coin to drop through to the other end and out. If it drops through, the hose is clear. If not, the easiest way to clear it is to plug the hose in to the exhaust port of the vacuum, place the other end into a large garbage bag or point it outside, and turn on the vacuum. This will usually clear a blockage.
Leaks that are severe enough to result in no suction will be readily apparent as tears, cracks, or cuts in the hose. A crushed hose will also result in the loss of suction.
If suction is fine at the end of the hose, do a visual check of the wands. It's unusual for them to be blocked, but not impossible.
Check the power nozzle above and behind the brush and where it attaches to the wand. The elbow can catch long objects resulting in a blockage.
If there don't appear to be any problems with the above mentioned items, you need to take the vacuum, with attachments, to a repair shop to have it checked. It may need a new motor, but that would be due to worn out or broken fans, and that is unlikely with Electrolux vacuum motors years older than that.
Dec 01, 2013 | Electrolux Guardian Bagged Canister Vacuum
Why would the vacuum have no suction?
if the motor is running it could be a belt a clog or a hole somewhere else in the hose
Feb 16, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
How do I switch the vacuum from floor to accessory suction
It automatically switches over when you disconnect the hose from the power nozzle. No suction it getting to the power nozzle, so the suction is only through the attachments. If there is no suction through the hose, check for clogs in the hose and in the tank where the hose plugs in. Also, check the screen at the bottom of the tank. If there is a clog in the hose or tank, then there also will be no suction to the power nozzle.
Remove all clogs and you should get suction.
Dec 19, 2010 | Hoover U5721-900 WindTunnel Upright Vacuum
Why has air suction pressure has dropped off to almost no suction? Filter cleaning did not help.
Do any of the ports have greater suction than others and are they closer to the vacuum motor unit? You appear to have a piping clog and locating it's position is the primary problem. If you have a portable vacuum, try placing it's hose in the exhaust port of the main unit and insert the pickup hose in a wall port near the main vacuum so that both units are on. The combined suction may pull the clog loose and draw it into the filter of the main unit. The other remedy is to remove the piping from the main unit and see if suction is good at that point, then work your way out to the nearest wall port. Hope some of this helps!
May 24, 2010 | Electrolux Central Vacuum
No suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
No suction for Kenmore upright vacuum
You have not stated which model vacuum you have. Bipass vacuum have a bipass compartment which is under drive unit. Make sure there are no cracks around housing as this is where you vacuume is created. In order to have vacuum you must have airflow, in assences suction. No air flow, no suction. If the airflow is deverted somehow suction will stop. Your filter, your bag are all sources of air flow. Clog either and you lose suction. Start with loss of air, being cracks in housing,bag or filter
Feb 23, 2010 | Kenmore Vacuums
No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
May 05, 2009 | Electrolux Central Vacuum
Hi my vacuum (Russell Hobss 2200 bagless HEPA) seems to have just enough ( not loads) of suction til it reaches the cleaning head. the head does not appear to be blocked - but there is then almost no...
Generic problem for all Vacuums
Hi my vacuum (Russell Hobss 2200 Bagless HEPA)
Hi my vacuum (Russell Hobss 2200 Bagless HEPA) seems to have just enough (not loads) of suction till it reaches the cleaning head. The head does not appear to be blocked - but there is then almost no suction at all.
It also makes loads of noise when on- and an even louder noise when turning off.
is it fixable or is it dead?
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Well there seems to be maybe a few problems, the head may be clear, but the hoses could be clogged and or the HEPA filter could be clogged as well – if the hoses and wands are clear and the filter clean you may look @ a motor replacement depending on the cost or to buy a new vacuum and in some instances you can trade in your old vacuum for a new one – but check it fist from the suction head thru the hoses, wands and filters, B4 you decide to purchase a new one or to replace the old motor with a new one depending on cost. A rule to live by – the item cost more to repair that to replace – replace the item, if the repair cost (as an example) say $50.00 to $60.00 and to buy a new one would cost $100.00 – buy a new one.
Don – The Vac Man
Apr 21, 2008 | Vacuums
Suction loss?
hi samdan... have you checked all the hose attachment vents .. ie Under the vacuum as well... How long is it since you replaced the filters?
Try giving the Yellow cone inside a blow out. these tend to become clogged from time to time!
Regards Faggly
Mar 21, 2008 | Dyson DCO3 Absolute Bagless Upright...
Hoover Tempo Widepath Upright Vacuum - Blue Logo
205 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
