Question about Canon ZR200 Mini DV Digital Camcorder
Not seeing anything through the viewfinder when switched on
  • 126 Answers
Most cameras and video recorders now display picture either through the viewfinder or the LCD screen.
Your camera model allows the same. Although if you turn the lcd screen towards the subject (screen faces the same direction as the lens) then the viewfinder switches on.
Posted on Sep 26, 2009
Cant see anything through viewfinder
Do you mean the viewfinder or the LCD? To turn on the LCD, press the Start/Stop button at the back (near the viewfinder).
Jul 13, 2014 | Canon EOS 7D Digital Camera
Can't see anything through the eypiece
To switch between the LCD screen and the viewfinder use the button EVF/LCD. to switch back, use the same button.
Nov 04, 2013 | Pentax X70 Digital Camera
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
Viewfinder is blank, but the camera works normally.
Iris or Aperture not working its all time off so that you can not see through camera.You need to change Iris cable.
Mar 31, 2010 | Canon PowerShot SD430 / Digital IXUS...
Olympus E410 viewfinder problem
As far as I am aware, you can use the viewfinder OR the live view, but not both at the same time.
This is because a mirror has to flip up out of the way to reveal the sensor for the live view to work, and the mirror needs to be in the down position to reflect the image into the viewfinder.
Switch between the two modes and double-check if there is a problem.
Also try removing the lens from the camera and checking the position of the mirror. It could be that it has got stuck in the up osition.
Hope this helps!
Jun 27, 2009 | Olympus EVOLT E-410 Digital Camera
Cant see anything through camera
There is a button next to the viewfinder. When you press it, you go between the viewfinder and being able to see what you're shooting through the tiny video screen on the back. That should take care of it. Otherwise, it may need repair. Good luck.
Jun 24, 2009 | Nikon Coolpix 5700 Digital Camera
Nothing comes hrough the viewfinder
I jsut posted on this same problem. If you can playback a tape and see the picture, but can't see anything on the camera, the camera has a stuck iris assembly. It is caused by the iris actuator (a small motor like device) leaking oil on to the two slippery sheets of plastic that slide over one another to act as the iris. A good tech can pull the iris assembly out of the camera and clean it, but some techs will only do what Sony recommends, which is replacing the lens assembly (very expensive)
Sep 14, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Cannot record anything - can't see anything thro the viewfinder or in the screen
Hello grnca,
CCD Imager ( an electronic part) at the end of Lens Assy got defective thats why you can't see any result in camera mode.
Please contact nearset Sony repair shop for replacement of CCD Imager IC.
May 19, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
237 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
