Question about JVC HD-52G886 52" Rear Projection HDTV
Analog pwr board smoking
I just replaced power board,and my tv started smoking around the analog and the tv would not come on after that,i am afread that one of the boards have blown out,Is there anyone out there that can test and repair these boards?I don't want to keep replaceing parts.I have done some continnuity test on these boards,and i can;t tell what is bad.
  • 58 Answers
On this model there were two power boards used, i would look at the srp# on the power board and see if it is the same as the replacement. If you put the wrong one in it can burn up, but usually there is no damage to the rest of the set, just put the correct board in and power up. Hope this helped.
Posted on Apr 02, 2008
Samsung TV LN46B530P7FXZA version AA01, ser num AUCU3CUS300985R,
Change the video board. It seems like it is blocking power. The relay signifies that power is working properly.
Nov 14, 2016 | Samsung Televison & Video
I was watching the tv, when the screen went blank but the voice was still on, then smelled something awful, like something plastic melting, then noticed a lot of smoke coming up from the back of the...
Most probably, Electrolytic condenser in the Power supply to display circuit may have punctured resulting in smoke coming out. Take tv to service centre. There is no other option.
Good luck.
Rating the solution is highly appreciated.
Mar 15, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Replaced deflection pwr board on rca d52w23 projection tv and still no pwr at all ( this board had a burnt cap) please advise
is that voltage traceable  on that ckt when power on, forward that trace to horizontal area may be there's part open resulting your machine dead.
Feb 23, 2010 | RCA D52W23 52" HDTV CRT TV
Dd603 info only acrid smell/smoke from upper
INFO ONLY- POTENTIAL FLUIDS CONTAMINATING CIRCUIT BOARD
EDGE CONNECTORS
Jan 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Tv started to smoke took apart and found found the
I assume it was the power supply that you replaced? It is very likely that a fusible device on another board has gone open circuit to protect any damage due to the initial problem. Again I assume you have a plasma TV in which case there will probably be a problem on the Y or Z sustain boards which may also need to be replaced as this may have been the reason for the other board to burn up
Dec 20, 2009 | Televison & Video
Gateway 200arc motherboard problem
If there are two wires running from the power button on your case to the motherboard, take them off and try jumpering those two terminals with a jumper or something that will make contact for just a second and them take back off. Your power button may have fried along with the power supply.
May 18, 2009 | Gateway Refurbished $30 P1 TO USA - BOARD...
03 Mini Cooper Power Steering Fan will not run
2006 mini cooper s power steering fan seezed. replaced with new fan won't run?
Mar 30, 2009 | 2006 Mini Cooper
42" magnavox plasma started to smoke, has audio but no video?
power board replacement a burnt circuit is visible upon opening unit and removing the power board.
Jan 27, 2009 | Televison & Video
Samsung hc-p5252w 52
what you need to do to solve the issue is to replace the pwr deflection board. You can get one at the following link under the samsung parts category. Its the P59A pwr def board.
http://servicemanuals.vstore.ca/
Sep 17, 2008 | Televison & Video
Akai lct2785ta 27in lcd...
After a little consideration...I believe this is a problem with the Main Board (Part Number: E7802-004008) Because the Pwr Led is blinking..that tells me that the problem most likely is not the pwr supply, but the Main Bd which controls the turning on of the Pwr Supply. This part on Vance Baldwin will cost you $289.69...however...the part is on factory back-order..which tells me that there must be a great deal of these boards going bad in the field..for them to have none in stock.....if you are in warrantee...scream til they give you a new one...if you r not...order the board and wait a month or so until it comes in...then replace it.........good luck and remember to get all the screws back in!
mike
Jan 27, 2008 | Akai LCT2721AD 27 in. LCD Television
JVC HD-52G886 52" Rear Projection HDTV Logo
53 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
