Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door stops opening at about 2 feet.
For a few days it stopped at about 6 feet but today it is only going up the 2 feet. It will open with a bit of hand pressure from the bottom. It may need lubricating or maybe there is something wrong with the drive. It has happened in the past once or twice in cold temperatures. Nights are now dropping to low 40s.
    President:
  • 3,197 Answers
On the rear of the motor unit you will find the 'up force' adjustment. Increase this a bit. You need to also take the time to remove the cover and look at the drive gear. It is a white nylon gear just in front of the motor and may be going bad.
Posted on Sep 28, 2009
Why is my Miele dishwasher displaying "Open stopcock", even though water is flowing and I've cleaned the inlet filter?
There are 2 possible main causes for lack of water, given that you have checked water availability at the dishwasher.
1. The water solenoid valve in the machine is faulty or failed.
2. The motherboard in the control panel has a fault and needs replacing.
Unless you are a DIY'er I suggest you call a serviceman
Apr 06, 2017 | Miele Dishwashers
Horn goes off when it rains!!!
Check horn contacts for corrosion
Jun 13, 2008 | 1999 Ford F350 Regular Cab
Can't open the driver side door.
wd 40 will work wonders for sticking doors
Feb 22, 2015 | Cars & Trucks
Craftsman garage door opener problem
If you have eliminated the obstruction sensor, I would suggest a few things. Is the door spring set at the proper tension - usually check by releasing the door safety and manually closing/opening the door. It should balance about halfway up/down. Openers have limit switches for travel, if one is incorrectly positioned or faulty, it can cause similar issues. Openers have torque limit controls, if the motor thinks it is working too hard it will stop. Is the door greased and moving freely when you manually tested it for the spring tension? Are the gear sprockets firm and greased?
Sep 22, 2017 | managemylife.com Home Security
Garage door opener model 139.53985 DM opens only about 2 feet then stops then closes when the button is pressed again; will open when I put pressure on the door and continue that pressure all the way up.
On the rear of the motor unit near where all those white wires go you will find the 'up force' control. Increase this a bit and try. Make sure you don't have a broken door spring.
Nov 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door stopped opening!?!?!?!
Remove the cover of the motor unit and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad.
Dec 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener only opens the door 1-2 feet high and then stops. What could be the problem?
My guess is that you have a broken spring. Look at the springs and see if you can see a gap in one of them. If you pull the release and you can't open the door without struggling then you definately have something wrong. The opener is trying to heft weight that it is not designed for and is stopping itself to prevent damage.
Oct 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
2006 dodge caravan power door will not open
You will need to pull the door panel and most likely replace the latch assembly.
Dec 01, 2008 | 2006 Dodge Caravan
Door opens only 6 inches and stuck
I would try jumping a wire across the white & red terminal to see if your safety sensors are working Properly! If your door opens you have a loose connection or faulty sensors.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
186 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
