Question about Toshiba Satellite 2455-S305 Notebook
I have three Toshiba Satellites, 2455-s305 (an older model with desktop P4, 1G Ram, XP pro, etc.)They boot and run, but have problems: (1) When turning this one on, I must press the power button, then press another button within a few seconds, or it won't come on. Power off works fine. The LCD backlight also will not come on, even though the inverter is known good (runs fine on another computer). Power is present, the fuses are good, and the inverter works fine in another identical laptop, so I believe it is good. I assume the input control signals are not getting to the inverter to tell it to turn on, and set the brightness, or both. I have not been able to find schematics so I don't know what to look for; I have determined that there are nine connections to the input of the inverter: five are for power and ground, four are control inputs (?). (2) This one boots and runs fine, the screen works, as does an external monitor plugged into the VGA output on the back, but, the LCD backlight won't come on. I have tried replacing the inverter with a known good inverter with no luck. I have measured power available to the board, and the fuses are good; the chips are receiving power. (I have a light inserted at the top of the screen so I can read the screen when the backlight is off, so I know the machine works) Same conditions as number one, above. (3) The mini-pc board connections inside are connected to the correct Toshiba networking board (wireless), and I have tested the board in another computer where it works fine. But, this one doesn't seem to be able to "see" the networking at all; the device manager shows yellow question marks for them, and the properties boxes indicate the drivers can't be loaded, but I know they are present; the configuration for this one is identical to another working one. I've also swapped hard drives in case there is something necessary hidden on the drive of the working laptop). Opening the Networking window shows that the system "thinks" there is a VPN network board present, but there isn't; must have been from the previous owner. I have deleted the connection, the software, the drivers, etc., but no luck. As far as I can tell, the configuration of this one is identical to another one which works (again, I swapped hard drives just in case). I believe the BIOS is the same as a good unit; if that is a potential source of the problem, I can try burning it again with BIOS from Toshiba's web site. Seems like checksum would show a problem if the BIOS is bad, though... The LCD backlight comes on, but, the keys which control brightness on the keyboard (Using Fn key) have no effect on the brightness, nor do the icons showing that brightness is being adjusted show on the screen. The brightness functions seem dead. Each of these computers is several years old, but they are valuable in the application they are used for, and there is no money to replace them. If you have any ideas about where to look for problems, I would appreciate your help. I have found a field service manual for this model, but it does not show schematics or other most technical information; it only shows how to replace major parts as assemblies, etc. Many thanks, Larry
  • 40 Answers
Turn off- unplug power- remove battery 1minute replace batt power cord press and hold zero restart while continuing to hold zero 30 to 45 sec screen will flash when you see cursor blinking let go... now you will have option to restore to (out of box state) select each time.( finish when prompted) computer will restart several times DO NOT TOUCH MOUSE OR KEYBOARD until you are sure auto config is thru approximately 1 hr 45 min
Posted on Mar 11, 2010
Tip
I am facing a problem with Media Control Devices, I need to down load the same in my laptop.
Please help.
Nur
on Jul 24, 2008 | Toshiba Satellite 2455-S305 Notebook
My Toshiba Satellite 2455 S305 Boots but the screen stays black. I have tried an F8 startup with no results. Does the screen need to be replaced or is there another part that might have failed?
Hi ccavanaugh38...
It could be a faulty screen or inverter causing your problem.
To try and find out which one it is, hook your laptop up to an outside monitor and start the computer, if the picture comes on then the problem is the screen, if if does not come on then it is the inverter in need of replacement.
Please take time to rate me
Aug 15, 2011 | Toshiba Satellite 2455-S305 Notebook
How do I install intel pro/wireless 2915abg in a toshiba 2455 laptop?
Go to toshiba website. Click on support. Click on download. Choose a category, since this is a laptop. Select laptop and for the family. Select satellite. For the model, type on the model finding filter the 2455-S305 then click go. slect your all operating system and wi-fi. you will see there the available driver for your pc.
Apr 07, 2010 | Toshiba Satellite 2455-S305 Notebook
Require part numbers for 2455-S305 hinges.
Toshiba Satellite 2455-S305 ...
Left Brake Hinge - P000368300
Right Brake Hinge - P000368310
http://www.impactcomputers.com/p000368300.html
http://www.impactcomputers.com/p000368310.html
Oct 06, 2009 | Toshiba Satellite 2455-S305 Notebook
2455-S305 goes to black scr w_fast blinking cursor
Hello there:
when you replaced the hard dive did you go into the bios and make sure that the harddrive was recognized and set up as the primary drive.
also you may be able to get around this by pressing the reset buttona on the back of the unit and hold in and turn on the power at the same time
than release after 10 seconds and if this still doesent work try to boot by pressing the f12 key as it starts up ok?
best regards michael
Sep 14, 2009 | Toshiba Satellite 2455-S305 Notebook
My toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Mar 19, 2009 | Toshiba Satellite 2455-S305 Notebook
Toshiba satellite 2455 series unable to reboot windows xp/
whats the orig OS installed on your machine? where do you get that recovery cd's ? does it come with the laptop? maybe you've got the wrong OS/ recovery disk with you. Do you have an XP/VISTA installation disk?
Dec 30, 2008 | Toshiba Satellite 2455-S305 Notebook
Toshiba Satellite 2455-S305 Notebook Logo
234 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
