Question about Boating
How do a seperate the lower unit on a 2000 40 hp yamaha
  • 677 Answers
On the lower unit you have a side plate to undo the gear connection.It may be near the upper housing.Then you have the g/box nuts.Undo all of these.Now all of these are off,the lower unit will drop.If not,a rubber mallet softly around the sides of the lower casing.The g/box nuts are below or near the flat cavitation plate.Not the ones near the propeller.Lower it gently and watch where the water pump tube goes.Whilst the g/box is off,I would do the water pump.Its 4 bolts and takes about 20 minutes.The parts are cheap and worth doing while the box is off.Make sure a high temp grease goes on the top of the driveshaft before it geos back in.Hope this helps
Posted on Sep 27, 2009
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
Yamaha 40 hp outboard
Look below lower mountings you will see the shift rod with along nut and a lock nut,undo long nut,do this with motor in reverse gear,some 40s have a stainless plate cover which you have to remove first
Aug 18, 2014 | Clymer Marine Maintenance and Repair...
15 hp yamaha not shifting stuck in gear
First, check the linkage under the motor cover. It stoops you from given the engine too much throttle when the motor is in neutral but can jam the system if you try to shift out of gear at too fast of speed. Or a link in that system could be broken/loose. If all looks OK the check your lower unit oil. If none or water, the gear case could be trash.
May 26, 2014 | Yamaha Impeller, 8, 9.9, 15 HP Outboards...
Take apart a v592 yamaha remote
Using a small blade screwdriver you have to now pry the two parts open.
Feb 20, 2014 | Yamaha Televison & Video
How to pull lower unit on 2007 70hp yamaha?
What do you mean by "Lower Unit"? Also what is the model of your bike? A lot of Yamahas have 70 bhp.
Apr 10, 2013 | Motorcycles
25 hp yamaha outboard powerhead removal
Remove Cowl ,Undo Four Bolts Securing Lower Cowl,Then Undo Bolts Securing Power Head, Disconnect All Attachments To Power Head From Cowl +any Electrical Connections ,Lift Power head Out
Mar 07, 2013 | Boating
Need Parts diagram fo 25 H.P. yamaha lower unit
Most modern outboards had 2 tapped holes in the casting which would let you put a steering wheel puller on that part wit some all thread and push aginst the end of the prop shaft to get that piece off the lower.o
Sep 04, 2012 | Boating
Yamaha 30 HP 3 cylinder 2 stroke
pull the spark plugs and see if they look like there burnning the same if so then i dought its a spark issue and if it was in the lower unit u wouldnt here a loud anything it sounds like a rod bearing i have had the same thing happen to several yamahas under a load
Jul 06, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
69 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
