Question about Horton EZ-Crank Crossbow Cocking Aid
The crank release broke on my quickdraw on the first attempt. How can I repair/replace this part?
Cable broke on hood release. It was having no issues and when it was last pulled it broke.
This is a tough one. you will probably have to get the car raised on a lift and look up in there to find the release and pull it with needle nose pliers. Before doing that, take apart the release handle inside the car and see if it is broken lose there. If it is, pull the cable with pliers. Good luck.
Jun 11, 2015 | 1999 Oldsmobile 88
The crank to my table top drill press broke, can it be replaced or repaired
you don't specify what break it is but i guess it can be repaired but not enough information on the break or where it broke ,is it the leaver or the gears or striped on the shaft??
regards pete
Mar 16, 2015 | Drills
Ink release lever in brother MFC-6490cw broke
Did you ever resolve issue with broken tab. I have same problem on my black cartridge release tab, and am wondering if I can need tab or can salvage. Thanks!
Nov 17, 2012 | Brother MFC 6490CW InkJet Printer
I have to repair my Schwinn airdyne bicycle. I cannot separate the lever that is on the crank which attaches to what handle. A piece broke off which makes the pedal wobble and I have the replacement gear...
I can only assume you are attempting to remove the crank from the bottom bracket. This sounds like an square taper bottom bracket.
As such you are more than likely going to need a "crank puller" which is a special tool that threads into the large threads in the end of the crank and will allow you to push the crank off the bottom bracket as you tighten the center bolt (on the crank puller tool)
If you have a gearing puller handy you can also make that work with a little fanangaling.
Mar 01, 2011 | Cycling
Truck f150 2003 5.4L turns but doesnt start....
sounds like the belt broke before you got home and it ripped the wires out of the crank sensor.
I would think the crank sensor is damaged and will need to be replaced.
won't start with a good one.
Jun 24, 2010 | 2003 Ford F150 Regular Cab
My son dropped the Hoover Floormate hard floor cleaner and a black piece with a spring came out. I dont know where it goes, and now the handle wont stay up.
From your description you have an issue with the pedal release in the base. this model is the original series, and I would not put too much money in the repair. not an easy cover to remove. check the base wheel assembly. the black pivot points break on these when dropped. If it is broke the part itself cost about $18. Cosider the overall performance and other repair items to determine worthwhile repair.
Oct 03, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
2007 Jeep Wrangler Unlimited Sahara
SUBJECT:
Long Crank Time Due To Possible Contact Of Camshaft Sensor To Camshaft Gear
OVERVIEW:
This bulletin involves the replacement of the engine camshaft sensor.
MODELS:
2007 (JK) Wrangler
NOTE: This bulletin applies to vehicles equipped with a 3.8L engine (sales code
EGT).
SYMPTOM/CONDITION:
The customer may experience one of the following conditions:
a). Long engine crank time.
b). Two engine start attempts prior to engine starting.
c). Due to the “TIP Start Feature” on automatic transmission equipped vehicles, once the
ignition key / switch has been released from the “START” position, the starter may stay
engaged for up to 10 seconds while the engine attempts to start.
The above conditions may be due to the position of the camshaft sensor to the camshaft
gear. The sensor spacer gasket may have come loose during engine assembly and
caused the camshaft sensor to be adjusted too close or in contact with the camshaft gear.
DIAGNOSIS:
If the above condition is present perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1 04686353 Sensor, Camshaft
Jul 12, 2009 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Horton EZ-Crank Crossbow Cocking Aid  Logo
133 people viewed this question
Top Horton Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Horton Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
