Question about Patton U2-1487 Floor / Box Fan
The power switch caused a circuit to blow when I turned it on
    Problem Solver:
  • 12 Answers
Sounds like you need to box that back up & send it back to where ever you got it fro
Posted on Sep 27, 2009
I have a 2004 chevy surban that keeps blowing the ignition fuse what can cause this
You have a direct short to ground on that power feed circuit . You need to find a power distribution diagram to see what all gets is power from that fuse . Isolate the circuits till the fuse doesn't blow any more , then trace out that circuit that blows the fuse .
Which Ignition fuse ? Which fuse box is it in ? under hood , passenger compartment ?
IGN A
40A
Ignition Switch RUN, START, RUN/START/ACCY
IGN B
40A
Ignition Switch RUN/ACC, RUN/START
Could be ignition switch problem , Chevy has had problems with them .
Jul 06, 2016 | Cars & Trucks
WHEN I TURN ON THE IGN SWITCH TO START POSITION I KEEP BLOWING THE FUEL PUMP FUSE BUT WHEN I REMOVE THE INJECTOR RELAY IT DONT BLOW THE FUSE
I would think that either the power wire feeding the pump or the pump itself is grounded and causing the fuse to blow. Pulling the injector relay is opening the circuit and not feeding power to the pump would be why it doesn't blow the fuse when it is removed.
Aug 12, 2015 | 1999 Mazda 626
Brack lights wont light up on my 1988 ford ranger we keep blowing fuse and put in new brake switch
If you keep blowing the brake fuse than you have a short in the system. Unplug the brake switch. Install a new fuse. If it did not blow than the problem is after the brake switch. Next unplug the turn signal switch, then plug the stop light switch back in and press the brake pedal. Did the fuse blow. If not than the wiring is good in between the two switches. With the turn signal switch disconnected use a jumper wire in between the light green wire (power from the brake switch) and the orange with light blue wire (power to the right brake lamp). If the fuse blows than there is a short in the right side brake circuit between the plug in and the rear socket assembly. If the fuse does not blow than jump from the light green wire to the Light green with orange wire (power to the left brake lamp). If the fuse blows than the problem is in the left hand brake wiring circuit.
Sep 04, 2013 | Cars & Trucks
30 amp Starter/Ignition fuse keeps blowing when i turn the ignition key. The instrumentpanel lights are dim and then the fuse blows.
I am assuming you are talking about the circuit that powers the key switch. I'm showing a fuseable link to the starter relay instead of a fuse.
If it is the circuit that powers the switch, I would disconnect the switch and see if the fuse blows as each circuit is powered one at a time using a jumper wire. You can get 30amp circuit breakers that plug into the fuse slot to use while you are testing circuits.
You may need a repair book or shop manual to find out what is powered by that fuse since it is most everything on the car.
Mar 01, 2013 | 1997 Dodge Avenger
KLH ASW8 Powered subwoofer keeps blowing 3A-250V fuses
The transistors at the output stage of the sub amplifier circuit might be shorted so each time you power on, the circuit draws a very high amount of current which causes the fuse to blow. It's definitely a problem with the circuit so using a higher current rated fuse would probably just result in damaging the amp even more. You should ask a qualified electronics technician to take a look at it. I hope you can fix it.
Oct 17, 2012 | KLH ASW8100 Subwoofer
How do I diagnose a recurring blown fuse in a gmc acadia 2009 50 v causes car to get stuck in park, no power windows, no lights, no temperature controls, power locks
You buy the GM factory manual and then use the wiring diagrams to track down the systems the fuse supplies power to, and one by one you go through each circuit until you find the short circuit. There is no cut and dry way that works every time to find this type of an automotive electrical problem, I have been doing auto electric for 25 years and seldom does the same repair fix more than one car or truck. You can also rent the manuals for download at this site for about $40 per year, a great deal. www.alldatadiy.com
Jan 31, 2012 | GMC Acadia Cars & Trucks
Wind shield wiper blowing fuses
You have a short circuit to ground when the switch for the wipers is turned on. It does absolutely no good to keep replacing the fuse until the short circuit has been located and repaired. I guess you are just starting to figure this out five fuses later.
The lesson here is that fuses do not cause electrical circuit failures. Electrical circuit failures cause blown fuses. There are many people that do not understand this.
If the fuse remains intact until you turn the switch on, you will find the problem between the wiper (combination) switch and the wiper motor assembly or the wiper motor itself.
Nov 23, 2011 | 2004 Kia Sorento
1999 Chevrolet Suburban. Stop lights are not working, what are the causes?
The power is not getting from the positive battery post to the brake light bulbs and back again to the negative battery post. I know this sounds stupid, but I have seen many people beat their heads against the wall trying to figure out a lighting problem when it really is as simple as "the power has to go from positive to negative"...Period!
So now, you could have a shorted brake lamp circuit that is causing the fuses to blow and cut the power from the circuit. You could have a bad brake lamp switch keeping the power from going where it is supposed to. It could be a bad turn signal switch. It could be burned out light bulbs. Last, but not least, it could be broken wires or a bad connector causing an open circuit.
Feb 20, 2011 | 1999 Chevrolet Suburban
The fuel injector fuses keeps blowing as soon as i open the ignition switch, it dosent even give me time to turn on the car before it blows again. the car has a new fuel pump installed by jiffy lube about...
There is a short circuit to ground on one of the circuits that the fuse protects. I need more information about your car and exactly which fuse is blowing. (Year, Make, Model, Engine size) All of the circuits powered by that fuse must be traced to find exactly what is causing it to blow. Most of the components can be eliminated as the cause by unplugging them one at a time and checking the fuse connector with a test light. (Otherwise, you could go through a lot of fuses trying to figure it out.)
Dec 24, 2010 | Kia Spectra Cars & Trucks
Subwoofer blows the internal fuse when receiver is turned on
possible solution - this can be caused by a fault in the receiver unit. the sub has a triac 'high side switch' circuit that can cause the fuse to blow if it doesn't get a good switching signal e.g. if the receiver power supply is not running at the full voltage. check the plug pack wire for damage, check the 12v input area on the receiver board for dry joints, particularly the power input socket. hope this helps.-pj
Dec 11, 2008 | Bose Acoustimass 16 Speaker
Patton U2-1487 Floor / Box Fan Logo
71 people viewed this question
Top Patton Dryers Experts
Tom Chichester
Are you a Patton Dryer Expert? Answer questions, earn points and help others
