Question about Homelite Garden
What is the proper mix of oil/gas for a homelite xl chainsaw?
    President:
  • 2,220 Answers
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Sep 26, 2009
Correct fuel mixture for homelite xl cahinsaw UT10695b
50:1 unleaded fuel,1 gal gas to 2.6 ounces of 2 stroke oil mix
Jul 17, 2016 | Homelite Garden
I have a HOMELITE XL-12 chain saw. Web sites say it takes a mix of oil and gas. But mine has a place to put oil in. Which should I do?.
The mix of oil and gas should be a 32:1 ratio which is 4 oz. of oil to every gallon of gas. I am assuming that what you are seeing is the oil tank for the bar oil. You need to use bar and chain oil for this tank as it is what keeps the chain lubricated. Do not use two cycle oil for the tank marked oil.
Apr 15, 2011 | Homelite Garden
What type oil for chainsaw, both w/gas for fuel and also chain lubrication
You mix 2 stroke oil with the petrol/gas at a rate of 40:1 (40 parts petrol to 1 oil). For longer life use a good quality oil like Husqvarna or Stihl rather than the cheaper types you buy at car service stations.
The oil you use for the chain lubrication is just known as chain oil and can be bought at tool hire outlets.
Mar 29, 2011 | McCulloch Chain Saw Scrench For Homelite...
I have a Homelite XL Chainsaw, What is the recommended gas/oil mix, please? Clive
I have an older homelite that uses a 40 to 1 mix. It is about twenty years old but I think that is what homelite still uses.I hope this helps you. Thanks
Dec 27, 2010 | Garden
What fuel mix does a homelite xl-130 chainsaw require?
the homelite xl-130 gas/oil ratio is 32:1 meaning one quart of gas and one oz of 2 cycle engine oil or one gallon of gas and and one 4oz bottle of 2 cycle engine oil.
Best,Regards
obliqueridge
Nov 10, 2010 | Homelite Garden
XL UT # 10655A Serial # HL1490086 XL 2 Serial # 40152376 Recently bought these 2 saws and have gotten 3 answers for the gas/oil mix. Can you tell me what is the right mix??
Run what ever fuel/oil mix you are comfortable with. A run lean condition is most often caused by an undetected air leak leaning out the mixture to failure. A couple of ounces of 2-cycle oil will not prevent its occurrence. If an owners manual (OM - I tried) is ever located it likely says 32:1. Most modern saws recommend 50:1:
Oil Mix Ratio:
In the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear
Sep 18, 2010 | Homelite Garden
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Have an older XL 16" Homelite chainsaw UT10695, Ser. No. HO0681042. Can't find manual for gas/oil mix ratio, thought it was 32:1??
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/87d4d17cf11a7c8b88256c280064b0b8?OpenDocument
XL-12 and 15 agree with your mixture, no 16 listed.
32:1 = 1 gallon of premium fuel to 4 ounces of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Homelite Garden
Garden Logo
469 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
