Question about Pioneer TS-A6872R Car Tweeter
Splice the wiring provided with the speakers to the factory ford wiring they both have a stripe??
  • 344 Answers
Typically the wire with a stripe signifies negative polarity, so if you are wiring your speakers in phase (+ to+ and - to -) then yes you are good to go. Something you may want to consider are connecting crimps. They are just little pieces of plastic that you connect your add on speaker to then they crimp onto the wire you are connecting to using sharp metal clamps, this limits the ammount of factory stock wire you would normaly be exposing and also stops the need to sever or cut a wires factory connection, in turn preventing resistence in the wiring. The less resistence a wire has the easier and more clear it can accept signal. With radio's speakers and amplifiers the more resistence a wire has the more static you will hear in the lines.....I hope this helps you out
Posted on Sep 27, 2009
Testimonial: "big help thank you for the info"
How to hook autotek693T speakers in cparice classic 1992???
yeah, you are going to have to cut off that factory speaker connection, but leave a few inches of wire on the end so you can re-attatch that connector later, should you sell the car, re-install the factory speakers and keep your after market speakers for another car. one of the wires has a stripe on them, (never mind the color) connect the stripe factory wires to the stripe speaker wires with 'wire-nuts', or twist the bared wire and tape them with electrical tape, the stripe wire to the positive speaker post. the other wire will of course go to the negative speaker post. once you have both speakers wired up, play some music with good bass, and move your speaker balance from one side to the other, if your speakers are connected properly you will hear more bass with both speakers than with the balance all the way left, or all the way right.
Oct 17, 2013 | Car Audio & Video
How do I splice my new SPE-6090 Alpine Speakers to my 200 honda civic stock wiring.
if the pioneers already had the wires in that where solid white&white wid a black stripe you can solid white as positive & white wid black stipe as negative same with other speaker except wires should be solid grey & grey with black stripe wich would be your negative if not the best way to go is wire the darkest factoy wire as negative & the lightest color as positive hope this was helpful
Mar 05, 2013 | Alpine SPE-6090 - 6"x9" 2-Way Car Speakers
I have a 2005 f150 lariat super crew, I want to change the factory speakers and put some after market speakers, but my question is does anybody know how to tell wich is positive and negative in the...
For the std single or 6 disc changer, non DVD
Front
L + : Orange w/ Light Green stripe
L - : Light Blue w/ White stripe
R + : White w/ Light Green Stripe
R - : Dark Green w/ Orange Stripe
Rear
L + : Gray w/ Light Blue stripe
L - : Tan w/ Yellow Stripe
R + : Orange w/ Red Stripe
R - : Brown w/ Pink stripe
Dec 30, 2010 | 2001 Ford F150 Styleside SuperCrew
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
Hooking up amp and subwoofer to stock radio
Are you sure that you want to attempt this?
It's a nightmare if you never have worked on any kind of car stereo. I've installed my share of after market stereos, so I know it's lots of brain work and patience.
The color of the speaker wires are the only wires that you can probably identify right off the bat. It's not too complicated to attempt yourself. If you have put in an after market stereo before. Your Lexus has factory installed rear deck speakers. Look at the bottom side of the rear deck. Pop your head in the trunk and look up.
On the right speaker there are 2 wires and on the left speakers there are 2 wires.
I think that all 1991 Lexus LS models came with factory installed rear deck speakers. The speaker wires are factory installed. You want to keep these original factory wires as is, but want some thicker higher wattage amp wires for your sub woofers, but write down the 2 left and 2 right speaker wire colors with the stripes, for example the red with yellow stripe, blue with red stripe, brown with orange stripe, black with white stripe and so on. There are four wires in all. Keep your wire colors on a piece of paper, because we come back to that later on.
You will need to run the thick red power cable to the car battery. That gets bolted directly down to the battery. You'll have to remove the bottom door jam that holds the carpet down. There might be a couple screws that you'll have to remove to pull up the jam. Tuck the red wire and lead wire in under the carpet and screw the jam back on when done. Do the same for the 4 thick higher amp speaker wires and route them to the back in the trunk.
Make sure to bolt the Black Ground Cable on the Chassis of the car for a good solid ground. The one thing that will cause a short is a loose ground wire or weak ground to the body.
Remove the radio from the dash. Be careful not to break the plastic around the radio. You should probably ask somebody for help, if you can not handle it yourself.
Now we need that piece of paper with the 2 left and 2 right wire colors with stripe laid out, you can do your splicing of wires. Simply splice the left and right speaker wires with the amp normal speaker wires that lead into the amp.
The amp may have stereo RCA jacks for input, I'm not sure which you have.
Make sure to match Left to Left and Right to Right. Now the AMP lead wire gets connected to the stereos power wire. This wire may be red or yellow, but I do not think it's gray. To test the wire splice into the yellow wire with the lead and start the car and turn it off. If the amp stays on with the car turned off, then change it to another wire. The goal is that it won't drain the battery with the car turned off.
There's some troubleshooting involve with factory installed stereos and making modifications. If you get this far you did a great job. You'll have it when the lead wire is connected and the car turns off and the amp turned off and when the car turns on and the amp turns on. Make sure you do not mess with the antenna wire. that turns on and then shuts off after the antenna is up.
Aug 28, 2009 | JBL GTO804 8" 4-ohm Component Subwoofer...
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
DEH-1330R CAR CD PLAYER WHICH IS POWER WHICH IS SPEAKERS
Wiring is pretty much standard for all 4 channel radios. red is switched, yellow is your memory (constant power), black ground, purple/purple-blk, white/white-blk, grey/-grey-blk and green/green-blk all speakers the solids are positive and blk stripes are negatives. orange is illumination, blue maybe 2 are amp switched for power on/of and the other power anteanna. Its easiest to get a wiring harness for your car it will connect color to color and then plug directly into your factory harness with no splicing of the wires so when you trade in/sell your car the factory radio goes back in with ease.
Aug 06, 2009 | Pioneer Car Audio & Video
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
Power seat still wont move
uys what I found on mine was under the fuse box panel, Ford did a factory splice.Orange w green stripe wire or vice versa been a while, that splice turned green and coroded inside.All i had to do was replace that splice with my own and all three worked again.Quite an easy fix.Good luck.
Apparently you are not the only one with this problem!
Dec 21, 2008 | 2005 Ford F-150
I need to bypass the factory amp in my 97 ford expedition
the amp is in the rear panel pass side if you have the Mach sound system. There are 5 wires going into the amp and 2 going out to the sub.
Light Grn w/ Purple stripe is the 12v power (thick)
Blk w/ Grn Stripe is the grnd (thick)
Drk Grn w/ Pruple stripe is the remote (thin)
Red w/ blk stripe is sub high output +
Drk Brown with Orange is the high output -
Jan 09, 2008 | Car Audio & Video
Pioneer TS-A6872R Car Tweeter Logo
103 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
