Question about GE Spacemaker JVM1640SJ Microwave Oven
I have lost the spring that opens and closes the top vent when the unit comes on. Where does it go and where do I get one
  • GE Master
  • 9,047 Answers
Form most brands, you can find helpful exploded view diagrams and order parts by entering your full model number here.
I
f your brand is not listed, try Encompass here or call them toll-free at 866-779-5835.
Posted on Sep 28, 2009
I have a Panasonic Model NN-P295SFR microwave. it just stopped the other day.
Have you had a power surge or outage? sounds like the main circuit board lost its programming.
Sep 22, 2017 | Panasonic Microwave Ovens
Samsung microwave not working
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
Apr 02, 2013 | Samsung Microwave Ovens
Light not coming on
please use the common sense , clearly, and logically and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Aug 02, 2012 | Microwave Ovens
E305075FPSA HighSpeed Eletrolux the door appears to not be closing tight.
No! this not normal, I'am concerned about microwave leakage, and a 1/8 gap is to much, should be tight against the seal "major safety factor" the door is out of alignment or the bottom latch is not secure "to much play" I recommend a pro simply because he needs test for leakage when the door is properly fixed.
Mar 22, 2012 | Electrolux ICON Microwave Combination Oven
Active Vent opens and closes continuously while unit is idle
I had GE look at the problem today (my microwave is less than a year old and under warranty). He replaced the cam louver and that seems to have fixed the problem. This is a small motor accessible by removing three screws and the active vent door. The whole visit was less than 15 minutes.<!-- from fixya rte -->
May 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Apr 27, 2009 | General Electric PVM1870SMSS Microwave...
Top front vent keeps opening and closing while fan is running
You can find your owner's manual online here.
That should help you clarify & verify proper operation.
If you still need help, you can contact Jenn-Air (Maytag) customer service here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 20, 2008 | Jenn-Air JMV8208A Microwave Oven
MIcrowave
check the door latches inside the oven, open the housing and spray some lubricants on the latches.
Feb 21, 2008 | Frigidaire FMV145K Microwave Oven
Buzzing noise, wont work???
The magnatron is shorting, overloading the high voltage transformer. From the picture this looks like an older unit and is probably not worth a magnatron replacement.
Dec 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
56 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
