Question about Cybernet Systems CyberPower CP1200AVR (BC1200) UPS System
Failure to initialize after a microsoft update was installed
I can't initialize the Cyberpower CP1200AVR UPS unit anymore after a Microsoft update that included a Cyberpower PTF.
I actually have had to unplug the USB cable and plug it back in after a reboot in the past. It seemed to actually initialize correctly every other boot, but this workaround (unplugging the USB cable and plugging it back in) doesn't even solve the issue anymore.
When installing the UPS some 4 years ago I remember not finding the correct manufacturer and model in the UPS configuration --- what values should I plug in there to make this puppy work?
I've recently moved to a rural setting and not having the UPS working, and the flakiness of the power out here has me very nervous.
  • jetgg Sep 26, 2009
    Well that was a good thought --- however when I go into Device Mangler and right click, get to the screen to roll back the driver, it tells me there are no backed up drivers found. I think I'll try to reinstall the software that came with the UPS.
    I reinstalled the software that came with the UPS --- no change.
    I then went out to the Cyber Power website and found a newer release of their software --- installed that and the problem was solved.
    President:
  • 1,015 Answers
Go into the control panel and find the device manager. Then locate the UPS unit and right click and update driver. Then pick roll-back driver. This should install the prevous driver that was working properly. Then when you do windows update make sure to set it to hide that update so you don't re-install it again.
Posted on Sep 26, 2009
  • muebe Sep 27, 2009
    Well I am glad you fixed it. Windows will usually back-up the previous driver so you can roll it back in case there is a problem with the new driver. That is strange that it got erased. I think Microsoft uses everyone as beta testers for their software.
My cyberpower 900avr smells burnt and wasnt not on. all i had plugged in it was my dsl and my printer..they all work in another socket... around the socket on the wall where you plug you can see a ring but...
inside your unit there are 2 power boards that convert a lot of current to and from the battery - complete failure on one of theses boards is a common problem and it's a terminal one.
if the mains power board has failed then yes, it has indeed overstressed the wall plug and you will have to completely replace it as soon as possible.
Apr 11, 2011 | CyberPower OfficePower 900AVR (C910-1000...
Nececito la bateria para cyberpower 625 avr la tienen y cuanto cuesta
http://www.osibatteries.com/showproduct.aspx?ProductID=9521&SEName=cyber-power-office-power-avr-625avr-ups-system-battery
Here is the replacement battery. Open the unit, disconnect the old battery, connect the new battery, and put the unit back together.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 22, 2011 | Cybernet Systems CyberPower 625AVR...
CyberPower CPS825AVR trips after 5 seconds
Needs a new batter most likely. The same thing happened to my CPS825AVR that I use in my home office. Emails to CyberPower went unanswered so I had to solve it on my own. It uses a lead acid battery much like those used in emergency lighting, and not unlike a battery in your car. It will initially fail to keep your electronics on after a power failure, just shutting off and beeping like mad. Then it will fail to stay on entirely. Try holding down the red reset button for a period of time. It may reset, but chances are it will not work after you unplug it from the wall to simulate a power outage, and will need to be reset again.
For me the first failure occurred when the unit was left in storage. Like most batteries a lead acid battery if left uncharged will deteriorate and be unable to hold a charge. The second battery purchased online just failed after barely more than one year. It was a battery made by Werker, which is a very common replacement battery for emergency lighting also. At this point I am not going to spend any more money in this unit. It is unclear to me as to whether it is a lousy battery or the unit is unable to maintain a charge in such a way that the battery will survive a long life.
I will buy a UPS made by APC, I am using an APC for my entertainment system now. They are more readily supported and offer more options with regard to replacement batteries. I suggest finding a model to suit your needs and then search to see what support there is for it. I got about 5 years out of the first battery and was able to easily get a replacement online. The APC batteries are also relatively competitive in pricing so there is less need to pursue an aftermarket brand.
May 15, 2010 | CyberPower 825AVR (cps825avr-sc) UPS...
CyberPower UPS - unit fan does not work. Is the
It may not be dead yet. Does it supply output? You have not mentioned. It would be considered dead if it does not give any output. Is the battery fine? If the battery is fine and there is no output then it may be dead.
So, check the battery for any sign of life.
Check the output.
Check output with it plugged into mains.
If all are negative then it is dead.
Nov 15, 2009 | CyberPower Computers & Internet
Power light is out. Is the unit dead?
Atypically if this is an older unit what you have is an issue with the battery. It will no longer hold a charge.
You will nee d to go to the vendor site and look for a replacement battery.
In some cases it may be less headache and cost just to buy a new one.
Oct 06, 2009 | Cybernet Systems CyberPower 625AVR...
Cp1200avr communications issues w/vista ultimate
Make sure you have the most recent version of the software which will disable the Vista battery options and allow our software to properly communicate with the battery backup.
You can download the most recent version of the software from our website at http://www.cyberpowersystems.com/software/PPPE_V_1.2.2_Setup.exe
Please make sure to uninstall your old version before installing the new version.
If you have any questions, you could contact CyberPower Systems Technical Support at 877-297-6937, M-F, 8-5 Central, or email at tech@cyberpowersystems.com.
Apr 15, 2008 | CyberPower (CP1200AVR) UPS System
Backup unable to communicate with computer
Plz check your computer without ups.If it is runing there.And wattage of ups .It seem over load or shortage of ups.Check power cable.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 06, 2008 | CyberPower 1350VA UPS w AVR & LCD...
CyberPower 825AVR backup
The cyberpower website hosts the software for free. Go here http://www.cyberpowersystems.com/support/product-support.html select your model and it will take you to the appropriate software suites.
Oct 29, 2007 | CyberPower OfficePower 825AVR UPS System
Cybernet Systems CyberPower CP1200AVR (BC1200) UPS System Logo
91 people viewed this question
Top Cybernet Systems Computers & Internet Experts
David Payne
David Payne
Are you a Cybernet Systems Computer and Internet Expert? Answer questions, earn points and help others
