Question about Sunglo Black Portable Liquid Propane Gas Patio Heater
THE HEATER WILL NOT LIGHT. WE CAN SEE THE PILOT SPARK AND HAVE BOUGHT A NEW GAS BOTTLE - NO JOY. CAN YOU HELP.
  • jean_jeffrey Sep 28, 2009
    Although we can see the pilot spark, it is not lighting. It's as if the gas is not coming through. We cannot hear the gas either. Any thoughts ?
    Sergeant:
    Champion:
  • 229 Answers
First turn off the gas and then check the owners manual that came with the heater,maybe a parts list,it sounds like the thermocoupler is bad, it sends a signal to the gas valve that the pilot is lit and then turns on the gas to the heater,you may find a replacement at a local hardware store,you need to get the old one out to measure the old one to know what lenght to get or the parts list will tell you,hope this helps,if you are not comforable doing this take it to a profesional gas service company.
Posted on Sep 26, 2009
Bad propane gas bottle - is it possible to get bad gas in new propane bottles?
The supplier's bulk propane tank either is not equipped with a moisture filter in the discharge line or the filter is ineffective.
Feb 06, 2017 | Heating & Cooling
Kampa Calor. Why isn't it lighting?
sounds like the line from the gas bottle is air locked .keep trying to light whle holding the button down longer
Feb 11, 2016 | Heating & Cooling
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
I have an AIM 3 Panel Gas Heater. I have just purchased a 9kg gas, connected everything as I normally did (last year), however the gas is not flowing through as it should. There is an ignition spark, but...
More than likely, there is air in the line from the gas bottle to the heater. Purging the air, by holding the heater's control knob down while in the Pilot position, until you smell gas, will solve the problem. This may take several minutes, so be patient. Once you smell gas, release the control knob and wait 5 minutes before attempting to light the pilot.
Hope this helped you and thanks for choosing FixYa.
Jul 29, 2011 | Heating & Cooling
I have a mobile bottle gas heater. To start, I depress the regulator and then the spark button. the spark works fine but the pilot light fails to light.\r\nGas bottle is full. No air in pipe. feed pipe not...
If it has been off for a while there might be a spider web in the orfice.
You would need to remove the pilot assembly and unscrew teh orfice to see if there is something blocking the orfice.
Oct 19, 2010 | Heating & Cooling
I have a Progaz heater with a full bottle of gas, the red igintion switch doesnt ignite and/or get the heater going, there is Start then 1, 2 3 on a dial, I have tried it on start and pushing the red...
There could a couple of problems. An easy and inexpensive thing to try is replacing the hose and regulator. If that doesn't help, the pilot jet may be clogged and you have to do some diassembly to get to the pilot jet and clean out the orifice. The last thing is that possibly the igniter is not creating a spark to light the heater.
Jun 26, 2010 | Heating & Cooling
We have a new gas bottle and new connection valve but the gas doesn't seem to be getting through to light.
IF YOU ARE SETTING GAS VALVE TO PILOT AND PUSHING DOWN BUTTON AND NO GAS TO PILOT YOU MY HAVE CLOGGED PILOT RESTRICTOR WHICH IS AT END OF PILOT TUBE WHERE YOU LIGHT PILOT ,REMOVE FITTING AND BLOW OUT DIRT. MOST RESTRICTORS ARE HARD TO GET OUT, JUST STICK PILOT IN SINK RUN WATER IN HOLE AND BLOW OUT WITH AIR PRESURE. DRY BEFORE RE -INSTALL. YOU SHOULD BE ABLE TO HERE HISS OF AIR BLOWING IN HOLE WITH LIPS.
Apr 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
The piolet light will not light. If I turn the
You may have a plugged orifice in the pilot tube assy. If you have any way of getting to the orifice with compressed air, and blow back, it may dislodge it, if it is plugged. If possible, carefully remove pilot tube at valve end first, so that if it is debris in there, it blows clean of the tube, so it won't clog again. Otherwise you'll have to remove complete assy. Another thing to try as well, is to shut valve off, loosen fitting at valve for pilot tube, AND MAKING SURE NO FLAME OR SPARK ANYWHERE IN THE AREA, take a spray bottle with dish soap and water mixed (bubble tester) and then spray at pilot fitting when it is loose, and push pilot, to see if any bubbles appear, indicating gas flow. If no flow there, then I'd get a new gas valve.
Jan 25, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Napoleon PTH10PSS Infra-Red Patio Heater
If you have a piezo ignition, then all you will hear is one click when you turn the knob. If I am guessing correctly, when you push in the knob and turn it, the gas flows to the pilot assembly, when you turn the knob far enough it will clilck and that sends the spark to the pilot assembly to light the pilot. Try turning the knob slowly before you get to the click, that will allow more gas to flow to the pilot. If this does not work, then you may have a blockage in the pilot.
Jun 29, 2009 | Napoleon PTH10PSS Infra-Red Patio Heater
Sunglo Black Portable Liquid Propane Gas Patio Heater Logo
124 people viewed this question
Top Sunglo Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Sunglo Pool and Spa Expert? Answer questions, earn points and help others
