Question about Brother HL-4050CDN Printer
HL4050CDN I cannot share it with other computers.
I cannot share it with other computers. It is connected directly to a XP SP3. The net is a router. In Vista the printer has no port.
3 Suggested Answers
mikaljalil
  • 15 Answers
SOURCE: share printer
First you have to set up a home network between both your computers, once that is established run an networking cable to your printer it should all be ran through a networking hub so all machines can communicate with one another
Posted on Jul 05, 2008
micromaster
  • 3614 Answers
SOURCE: I have a Brother HL2070N
hi there,
Because printers and networks vary, the best instructions for setting up and networking your printer should be in its users manual. Also, your network-ready printer may have come with installation software that can help you share the printer over the network.
There are three main steps you need to take when networking a printer, including the following: Enable the File And Printer Sharing setting, Make the printer available to all users, and Direct PCs to the printer.
For detailed instructions on sharing printers at home, please refer to the "Get Your House In Order" article in the "See Also:" section below.
For detailed instructions on sharing printers in a small business, please refer to the "Select & Share The Right Printer For Your Small Business"
Posted on Apr 14, 2009
I cant plot from AutoCad 2006, using My hp
hmmm.. we only have two computers at my work connected to a router. the designjet has a network card going straight to it. i connect to the router wireless and it reads vista. my boss connects to the design jet thru the router as well with a network card rj cable with xp pro. as for our printer it can be connected via router and does work fine but my boss has it directely connected to his computer and i share it off of his system. then we also have a zerox machine connected via router as well. maybe your router is going out? try a new one or a better one and see if that fixes it. it maybe defected or time for a new one.......
if it was working before then maybe its the router.
Jan 07, 2010 | Autodesk AutoCAD 2006
Can't ping Default Gateway (XP) From Windows 7
Make sure you are receiving a proper IP address from the DHCP server....If you run a cmd prompt (windows icon, type cmd and hit eneter, then ipconfig) you should see a 192.168.0.x address. If not, go to the control panel, network connections, manage network connections, and be sure that TCP/IP (V4) is set as auto-configure....
If you are sharing the connection through an XP computer, you will need to run the Internet and connection sharing Wizard on the XP computer, and transfger the settings on a disk to the Windows 7 PC. A simpler solution (assuming you are on a cable/dsl connection would to be to go to your local big box store and buy an Internet/Firewall router. It would also increase your security.
Dec 28, 2009 | Microsoft Windows Vista Ultimate Edition
My belkin router won't connect to my computer
I want you try and connect your modem directly and check if its working, if its working, there would be a button that says reset on the back of the router, press and hold it for 2 mins and try to connect again.
Sep 28, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
HELP SETTING UP A LAN SERVER WITH DC++
Window has everything you need for file sharing built in. If you have a number of machines connected to the same Router using a combination of wired & wireless then all you need to do is enable file sharing on each machine,. Re-boot & your files are now shared. .
Aug 02, 2009 | Microsoft Windows XP Professional SP3 Full...
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
Want to share 922all in one on xp desktop with laptop using Vista
I have a network running both an XP computer & a Vista computer. What I had to do after connecting them both to the router was make an internet connection with 1 computer, turn on the printer so everything the network was going to share was powered on; then run the network wizard on both computers. Once I did this the computer that the printer is not physically connected to installed the printer driver. Once this entire process was completed we had internet on both computers as well as both computers being able to send jobs to the same printer. Has worked great for over a year. Hope this helps you out.
Mar 16, 2009 | Dell 922 All-In-One InkJet Printer
Setup to share internet connection using directional antenneas
Make sure you have the wireless config settings identical on both computers i.e password,name etc.See if you can see other computers when you search for wireless access points.If yours is not there its your settings.If it is and you cannot access it check the password in notepad to see if both computers lettering are both the same.
Dec 15, 2008 | Logitech Cordless Desktop EX110
Cannot setup home wireless network between computers
Hi!
Since all computers are online, you do not need to change any setting on the router for the computers to share file or resources.
If you are using Windows XP - try this link:
http://support.microsoft.com/kb/304040
For Vista:
http://windowshelp.microsoft.com/Windows/en-US/Help/e2e03106-2546-4085-bd07-6c3ac95003111033.mspx
I hope that helps!
Good luck and have a nice say!
Dec 02, 2008 | 2wire 2700HG-B Router (2700HGB)
Losing internet connection when enabling ICS on the wireless network connection
Do not enable ICS on any of the computers that are connected to a router regardless if it's wired or wireless, you only need to enable ICS is if you don't have a router/server on your network(the purpose of a router is to share a single internet connection from your ISP). To connect your computer wirelessly to the router(on a Windows XP computer given that you do not have a 3rd party Wi-fi application installed) is to right click on wireless network connection on the System Tray(lower right hand side of the computer's Desktop near where the clock is) or you can do it the hard way by going to Control Panel then Network Connections and choose view available wireless network and under the list of available network that your computer can detect, select the network name(also called SSID) of your wireless router and try to connect(of course if you enabled Wi-fi security you also need to key-in the security key(WEP/WPA) you configured on your router and that's it both wired and wireless computer/devices connected to the router should work at the same time.
Nov 05, 2008 | Belkin (F5D7230-4) Router (587009)
Brother HL-4050CDN Printer Logo
18 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
