Question about Black & Decker Garden
My Black & Decker MM675 lost power. Cord tests good. It worked fine a few days ago. I tried to mow today and no power. Where do I start?
SOURCE: My swisher pull behind was working fine and I was
take the cover off above the ignition switch ckeck 4 loose wires if nothing is found wrong jump it at the selinoid if it starts go to the nearest perts store and buy a selinoid for an ole ford truck transfer wire exact and it should wrk fine
Posted on May 07, 2009
frcs68
  • 1605 Answers
SOURCE: electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
Posted on May 22, 2009
SOURCE: Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
Posted on May 24, 2009
  • 133 Answers
SOURCE: Black&Decker MM675 lawn mower height lever would not stay
I would look in my owners manual and get the part number for the height lever and order a new one. You could also try and wire the height lever so it can not move. I am not sure how it engages but you could may be try and bend the lever so it is tight and won't move. Just a couple of ideas.
Good luck
Posted on Sep 01, 2009
  • 52 Answers
SOURCE: Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Posted on Apr 15, 2010
Husqvarna YTH20K46 no power. HELP!
Not turning off sounds like an ignition switch problem. Not starting - then I think you should check the Low Tension side of the solenoid again to make sure there is current from the switch. If the solenoid's OK, the battery's fully charged with all the connections clean and tight, then it has to be the starter motor or engine. Check you can turn the engine by hand, if so then I would guess, it's probably the starter motor.
Good Luck
Apr 21, 2013 | Husqvarna Garden
Black and decker lawn hog 18 was working fine last time used but will not start now what,s the problem
while unplugged rotate the blade a few spins to move the brushes if there stuck make sure the outlet is good and try another power cord
Aug 13, 2012 | Black & Decker Black and Decker Mm575 18"...
Two-year-old Black & Decker 19"
if its not in the cord. it may be the brushes in the motor. if they are worn down and not hitting armature. motor will not run. good-day !
May 05, 2011 | Black & Decker 19" Electric Lawnhog...
Please advise if your Black & Decker Weed Thrasher model # ST4500, has been recalled? I purchased mine less than a year ago and used it now approximately 12 times and it is dead, no power? I have...
Black & Decker warranties all of their products for at least 1 year, and some of their units for 2 years. Go to http://www.blackanddecker.com/Service-Centers.aspx to find your nearest authorized repair facility. Do not return it to the store you bought it from.
Good luck
Dec 03, 2010 | Weed Thrasher For Gas Grass Trimmer Wacker...
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Black & Decker Cyclone won't power on
If the sander was on for a long period of time maybe 20 mins or so then the switch has probably stuck in the off position when you turned off. Try a new switch or test the old one. Try Solent Tools on 023 80578057 for spares or further advice.
Dec 10, 2009 | Black & Decker Black And Decker Cyclone 4...
Good luck
Aug 31, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Electric mower won't cut well
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
My black and decker leafhog blower/vac smells like something is burning
Black and Decker has issued a recall notice for Type 1 BV4000 because "a loose connection between the unit and an extension cord can create heat, posing a possible fire hazard" Says to STOP USING and call 1-866-853-2138 to arrange for free repair. (Found info by Googling "Black and Decker Leafhog", navigate to Black and Decker website and click "Important Safety Recalls" button at bottom of page.)
Nov 08, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Garden Logo
141 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
