Question about EA - Electronic Arts Need For Speed: Prostreet
Bsod on Startup
I get bsod every time i start the game, is their a fix for this?
  • 1,472 Answers
Streylem
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Posted on Mar 29, 2010
Samsung laptop RV511 BSOD
The BSOD is usually a sign that there is either a driver or hardware problem. If you have added anything since you got the laptop you should remove it. You should also try and run the system in "Safe Mode" (press F8 at startup). This causes the system to run without the specific drivers, and uses generic drivers.
May 21, 2013 | Samsung Rv511-a01 Laptop
My pc would start up, then flash this blue screen for a milisecond, then start up again
Log into Windows Safe Mode (F8) and turn it off Auto Restart by doing the following:
  • Right Click on “My Computer”
  • “Properties”
  • “Advanced” tab
  • and under the headline “Startup and Recovery”,
  • “Settings”
  • uncheck “Automatically Restart” box
  • press Ok.
Now the BSOD will not disappear and you can begin to fix the problem. To solve a BSOD problem go here:
http://tinyurl.com/29vpw4j
Aug 17, 2010 | Compaq Evo D500 PC Desktop
My PC boots up and then restarts. There is no set pattern to this however. It may be on for 2 minutes or 8 hours before it does this.I've tested the power supply, it's fine. Any advice?
One of the programs set to be loaded at boot fails, you get a BSOD and the pc restarts. You need to find what the BSOD says to stop all of that.
To see the BSOD you need to stop the pc auto-restarting:   Start / Control Panel / System  /Advanced / Startup and Recovery / Settings... > under System Failure un-check "Automatically restart"
May 26, 2010 | Computers & Internet
I hav an acer 5230e ,i want to install window xp but on window setup it shows blue screen error nd appear plz remove newly installed drive nd chkdsk on run /////////////tell me wht i do?
heeey dude ! I had the same problem.. and I just solved out how to fix the problem !.. the only thing you have to do is: Go to your Bios, and switch from SATA to IDE, and then it will be fine :-)
Apr 05, 2010 | Acer Computers & Internet
The ATI Radeon 3400 HD goes in an infinite loop
jrz3305
To bee able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
Thanks
Issken
Mar 18, 2010 | Lenovo ThinkPad T400 - Intel Centrino 2...
Plugged in the 1TB WD My Book Essential into my Dell Dimension 3100 running windows xp and the screen goes blue and I get a error stating "Bad_Pool_Header"
here's a solution I found on google:
BSOD the Solution:
Did you install Service Pack 2? Are you now suffering from the Blue Screen of Death (BSOD)?. Here is the solution. I have spent 4 days hunting down the cause of my machine crashing and have finally cracked it. Maybe other people have a different cause than mine so my solution may not work for everyone.
After installing SP2 I suffered many crashes. In particular the Screen would turn blue and display a message starting "Bad_Pool_Header". And ending with STOP: 0X000000019....
Then my four day hunt for the cause started.
BSOD Solution
Basically I found two causes of the BSOD.
Cause 1: Corrupted file or folder.
Cause 2: Microsoft Indexing Service
Possibly these two causes are linked.
Solution for Cause 1
Onen up Explore (right click the start button), and expand your directory tree, starting from the C: drive. Click on each folder in turn and see if any cause the BSOD to appear. If so, reboot, and simply attempt to copy the folder, and then delete it.
Solution for Cause No 2
Switch off Microsoft's indexing service. You can do this by clicking the start button, select "Run", then type "msconfig", then select the "Services" TAB, scroll down to the Indexing Service and Switch it off. Reboot your computer, and good luck - maybe it will work, It solved the problem for me.
At first I thought I must have a third party software or hardware conflicting with SP2, but even after I had disconnected the internet, switched off all items in the startup TAB of msconfig, was still getting the BSOD. I tried surface scans, chkdsk, scan disk etc all to no avail. I tried defragmenting the disk, but the frequent crashes may have made things worse.
I discovered the computer was now crashing after about 7.5 minutes of being switched on. It did not matter whether anyone logged in or not.
Finally I went to msconfig (Start Run, MSCONFIG) and switched off "process System.ini files, Load System files, Load Startup Items. And the comuter stopped crashing. So then I added the item back one by one until I discovered the Microsoft Corporation Indexing Service which was causing the crash. I switched it off and switched everything else back on and AT LAST... No more BSOD
Jan 01, 2010 | Western Digital My Book Essential 1TB...
Proxy host error BSOD on PH32DSP.dll
Many Windows 7 users are facing BSOD (Blue screen of Death) error.
Follow the below steps to resolve the error.
1. Startup in safe mode (tap the F8 key on your keyboard repeatedly as the computer is starting up)
2. Select a method of safe booting from the menu (first try with networking; if the crash still occurs, try without networking)
3. Once the system has booted, click the Start button and type MSCONFIG then press enter in Windows Vista (in Windows XP, click the Start button, then click “Run” and type MSCONFIG then press enter).
4. Go to the Startup tab.
5. Disable Kaspersky and any related items (e.g. kl1.sys), then press OK, then restart the system if it does not happen automatically. Startup normally (i.e. not in safe mode).
Alternatively you can launch the Kaspersky application and set it to not start at startup.
Aug 03, 2009 | Funk Software Computers & Internet
Every time i try to turn on my computer it shows bsod for a split sec and the restarts again? can u help?
You can configure Windows to not automatically restart when a bsod occurs. In the Control Panel, go to System and then select the Advanced tab. Then click Settings under Startup and Recovery. Clear the Automatically restart checkbox.
Now when the bsod happens, it will stay until you power down the computer. You can read the STOP error of the bsod and any potential file name. Now you can search for the exact error and solution.
This article on troubleshooting blue screen errors might help you further.
Jul 29, 2009 | Computers & Internet
Bsod 0xdeaddead. restart and when it wants to.
No programs added. Microsoft updates can crash to BSOD 0xdeaddead 0x00000000 0x00000000 0x00000000 0x00000000. When I restart it gos to bsod above. Will be working on a file and it will crash to the bsod above. Not every Microsoft update will crash in the process of installing but some have. No new hardware or software has been added for sometime now. Streets and Trips has been loaded and taken off several times because it will not run with out a startup error. Everything other than that works fine.
Aug 27, 2008 | Computers & Internet
EA - Electronic Arts Need For Speed: Prostreet Logo
151 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
Adam Jasar
Level 1 Expert
Nikki  Mclean
Nikki Mclean
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
