Question about Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor
Minn Kota 65lb thrust 24v
Is this unit for use with a 24v battery only or can I run it with a 12v also. I was wondering if it could run on both but to a max of 24v. I have no instructions for this unit as I have just picked it up at a garage sale
  • 76 Answers
Hello!
Your unit was desined to run on 24 Volts.
The control unit (electronics) will not run below 19 Volts (19 or 20, I can't remember) and the armature windings and magnets are designed for 24V as well. So, an easy answer is no your unit will not operate in 12volts.
Hope this helps out!
Mike
Posted on Sep 26, 2009
You can run the motor in 12v no problem...trust me! The motor will work fine however obviously at a slower speed! your max would be half of its potential.
Dont know where the post above came from but it is incorrect...sorry!
have a good one.
Q
Posted on Dec 10, 2011
The motor has two speeds. Very fast forward and very fast reverse. The speed control is not functioning
A lot of these units have 2 year warranty. Minn Kota web site list authorized warranty repair centers. The foot control unit most likely got water in the digital switch. If not under warranty any longer, open it up and see if any water bubbles in the sealed board where speed switch makes contact. If so you will need new foot control.
Sep 30, 2010 | Minn Kota Powerdrive 68PD V2 Pontoon Motor...
Lookinf for a manual for a minn kota model 55d
call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
Jan 19, 2010 | Minn Kota Endura 30 Freshwater Transom...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor Logo
420 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
