Question about LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur...
Fridge doesnt work, freezer works
The display on the freezer shows "ER" and on the fridge display shows "FF". I unplugged and plugged it in again and then it starts to run normally. However, after 3-4 minutes, the errors come back on and the fridge no longer works.
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Posted on Oct 19, 2009
    Master:
  • 363 Answers
Hello, everyone, have you ever played a game called RuneScape? I heard this game is very popular before, and now there are still many players, and recently I found a website may be able to help you, to share with you www.rsgoldfast.com
Posted on Dec 28, 2016
2 Suggested Answers
  • 363 Answers
SOURCE: fridge is no longer cooling. ER where the
Sounds like the FF(Freezer Fan) is wearing out or is worn out. This assembly supplies the circulation for the freezer as well as the refrigerator. When is slows down or stops the circulation of cold air to the refrigerator is the first thing that is effected. The minimum cost to replace this assembly is around $300.00
Posted on Jul 26, 2009
What does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 30, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge is no longer cooling. ER where the
Jul 10, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
FF error code
The ER-FF problem that you have is: ERROR -FAN FREEZER so it means that you have a problem with maybe the fan motor or if it's a bottom mount freezer maybe ice built up on the fan motor so it's blockin the fan motor.
Hope i helped u a little bit ! :)
Francois Pelosse
Jan 19, 2009 | Freezers
Er FF ON THE BORD
FF usually means the freezer fan is not working. If the fridge is cooling poorly, check to see if the fan inside is running while the compressor is running. If not, and if there's no ice jamming it, then you need a new evaporator fan. If the fridge is cooling normally and the only symptom is the error code, then it could be a problem in the electronic control.
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error code FF
I had the same problem. I can tell you that simply unplugging the fridge and letting it defrost
isn't going to work. You need to get take it apart.
I had the Er FF code about 2 months ago and let the freezer defrost for a couple hours and it
started working again. Then two days ago I got the error again. This time I decided to get inside
there.
First and foremost, UNPLUG the fridge and TURN OFF the water!
Next empty everything out of the freezer and start taking it apart. You have to get everything out
of it to get that back panel off. This includes the ice maker and the rails that the drawers slide
on.
Now that the freezer is completely empty there are two screws that hole the back panel on. In my
freezer one is a white screw high in the center and one was a gold screw in the little panel that
the ice maker hooked up to.
Next grab the back panel by the little fins on the top of it in the middle. Give it a good firm
pull, but take care not to yank it too far... it's still connected by wires back there. When I
pulled my panel out I found a HUGE chunk of ice on the top of the panel just to the right of the fan
that feeds cold are to the fridge. Get that thing off of there taking care not to damage the foam
insulation and watch those shiny metal fins that are behind the panel.
While you're putting it back together try to dry everything off as much as possible (I tried see the
bright side of the whole evolution and realized I could really clean my freezer).
Once it's all put back together plug that baby in, turn on the water, and enjoy the next four hours
as it gets back to being cold.
I'd say you need moderate tinkering skill to do this. If you only own one screwdriver and you never
use it you should probably call someone.
Hope this helps!
Jul 05, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer cold/fridge warm
You have a defrost issue and needs to be serviced by a qualified LG technician.  The freezer fan motor is blocked by a large chunk of ice behind the rear panel of the freezer section.  You will need to remove the rear panel to get access to the fan and get rid of the ice.  This will get your refrigerator working again but this problem will return.  You will need to have your control board replaced.
May 10, 2008 | LG LRFD25850 French Door Refrigerator
Fan in the freezer stop working ater a while
You may have a serious issue with the wiring harness inside the refrigerator.  You will need to have the technician come back out and check the continuity of the wires leading from the control board to the fan checked out.  If there is no continuity, it is not repairable.
Mar 13, 2008 | LG LRSC21935 Side by Side Refrigerator
LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur... Logo
616 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
