My mitsubishi medallion hdtv 1080 stopped working for no reason it just keeps giving me a blinking green light on the power button... what should i do? i already tried the reset button
    Genius:
  • 1,112 Answers
Have you lamp checked or replaced,
Posted on Sep 27, 2009
Older medallion 55" 1080...switched itself
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "input" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
May 14, 2011 | Mitsubishi WS-65413 65" Rear Projection...
TV won't work. Green light blinks continuously on front panel
Your particular bigscreen has a digital module located on the left rear of the unit, and is mounted vertically. This module can be removed and the shielding taken off. On the component side of the DM module is a small power supply circuit board which needs to have all five electrolytic filters replaced. The filters are typically 1000 micro farad at 25 volts and are easily obtained by you local electronics supplier or repair shop.
The reason your unit does not stop blinking is due to these out of tolerance electrolytic filters. They became out of tolerance when the unit was left unplugged during the move. Once the filters are replaced, and the module re-installed, the green blinking light will extinguish after about one minute, at which point the unit will turn on.
Apr 29, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi 65 medallion hdtv 1080
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
this has how to fix the blinking light check out this forum for more on this type of stuff
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?2/108250
Aug 27, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi 1080 HD Medallion
If the LED doesnt light. Check the fuses. the fuse many be blown. Unplug the set before you check the fuse.
Jun 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
May 30, 2008 | Televison & Video
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
Electro Med Services...
