Question about Bosch SHU3305 Dishwasher
Our dishwasher pools with water and this a.m. there was water all over our hardwood flooring. I drain the water 2 - 3 times a day. We moved in this house with no manual for the dishwasher.
  • Bosch Master
  • 2,605 Answers
The bosch dishwashers are known for faulty inlet/water fill valves. that is a very real possible problem, however, have a tech out immediately.
you can try a do it yourself approach with the valve. replace the valve with part number BT-425458. (your local parts depot should have it, or try an online store such as "AP Wagner" or "Sears". My shop carries it at our parts department).
*notice; The new valve should have the solenoid coil laying horizontal, the original likely will be vertical. they have a history of failing in the "open" position, letting water in even with the unit "off" I've seen many insurance claims due to this failure, especially in the late 90's early 2k's. I'm sure there are still thousands out there. I should add, other possibilities could be, one being back flow throuh the drain line (hooked to a garberator?).
*If it is only happening when nothing else is in use, i.e. water running in sink, garb. running, including the dishwasher, I'd bet on the valve.
hope that helps,
good luck
p.s. if you provide a model number you should be able to get a manual via a pdf on the b/s/h home site here, http://www.bosch-home.com/us
Posted on Sep 26, 2009
Hello Heatman101....I have a 2-3 year old Whirlpool frige,bottom freezer.The humidity in the past month around Ottawa Canada has been extreme.It seems on these days water is leaking on my hardwood oak...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 24, 2011 | Whirlpool Refrigerators
Frigidaire Dishwasher FDB2810LDC1 not draining
Sure its redeemable if you have the time and money. If I understand you correctly when you move the lowewr spray arm the water drains out? If this is the case then more than likely its a pump motor or solenoid. Reason I say this is on the bottom of the spray arm is a impeller and under that is filter and then pump impeller that drains the water. If its not draining but will by hand then its your pump motor or solenoid. When you start the washer then press cancel/drain do you hear anything? Maybe a humming sound. One more thing could be a thermal fuse for the motor. These are usually not resetable its a one time fuse if it blows you have o buy another one.Hope this helps
Jan 25, 2010 | Frigidaire 24 in. PLD2850 Built-in...
C-467/06 This is my problem its the inlet water and appears to be control valce? can you help' Water leaking on my hardwood floors.
if the unit is overfilling make sure the float moves up and down freely if the valve try to tighten the connector where the hose/copper pipe hooks up to the valve
Sep 10, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My ge dishwasher will drain but after a few hours
Could be a crack in the tub, bad seal at the pump if water is leaking out onto the floor. If water is pooling inside the DW then a bad water control valve allowing water to leak back into the tub from the source.
Jul 07, 2009 | Dishwashers
My dishwasher won't drain, and leaked out onto my hardwood floor!
I ordered a new hose and the problem is fixed! I probably could have just simply taken the old hose off and flushed it out; but the powdered solution, that is supposed to dissolve, had solidified and clogged the hose in several places. Strangely, it had also made like a filmy flap at both openings. Gross!
Jun 23, 2009 | Kenmore Dishwashers
Water collecting below veggie compartments water inside
Take you bastor and find the drain hole and blow air into the line to open it up. The drain from inside to the pan is clogged.
Jun 11, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water on floor and ice on freezer bottom
The problem is that the drain hole inside the freezer in the lower back wall is clough and the water from defrost doesn't go through that drain to the evaporative pan in the back by the compresor ,you need to clear thatdrain first meltting the ice in that hole with hot water until it goes through then once in a while (every 3,4 months put bleach into the drain to keep it clear .
Apr 22, 2009 | Frigidaire PHSC39EGS Side by Side...
Our Bosch Dishwasher Not Draining After Normal Washing Cycle
make sure the filter is not blocked by anything like a straw or just junk
Apr 02, 2009 | Bosch Dishwashers
Dishwasher will not fill with water
without a brand or model number its hard to be sure, but some types have a float cut out switch inside the washer. Its on the bottom inside and kind of resembles a plastic mushroom. The top should lift up and down easily. detergent will clog it up and keep it from moving. Just clean all the soap caked on it and move it up and down to see it it pushes a little switch underneath.
Nov 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU3305 Dishwasher Logo
166 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
