I picked up this TV rom a friend who had a son inherit it from a rich friend, it sat in a garage for a year in Las Vegas. The model # is HCL4715W, It is a Samsung 1080i HDTV Monitor, this is my first TV bigger than 30", first projection TV, and first HD TV.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Comments:
Sep 26, 2009
- Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009
when i turn on the tv the timer button starts to blink and it makes a noise every once in a while....
(More)
when i turn on the tv the timer button starts to blink and it makes a noise every once in a while. the tv sounds as if it turns on and then it has a black screen and i cannot hear anything. but the tv turns on and the remote works.
i was watching tv today and the screen and sound just turned off, i have the back of the tv pulled...
(More)
i was watching tv today and the screen and sound just turned off, i have the back of the tv pulled off so i can see inside but i have not touched anything, when i try to power on the tv the red light on the front just blinks, is there a fuse or something that i can check on
Started smokingfrom the I would call it the motherboard.and screen is blank.What would be the...
(More)
Started smokingfrom the I would call it the motherboard.and screen is blank.What would be the problem and how do I fix it?
Sony KP53S65. When unit powers on the sound starts up but the picture takes longer to display. The...
(More)
Sony KP53S65. When unit powers on the sound starts up but the picture takes longer to display. The picture then blinks on and off periodically for a minute or two before it remains on and works properly. The picture tint seems much redder than usual, could this have something to do power up issue? I opened the unit and vaccuumed/blew out all the dust, windexed the tubes and mirror. I then turned it back on with the back open and looked into the tubes while it was on. The Red and blue tubes have a clear image however the green tube image does not look nearly as distinct as the other two. Picture is crisp and sharp once it stops blinking except for the reddish tint. Could this all be the result of one problem and if so what do you think it is?
