Question about Sharp R-1481B Microwave Oven
A little louder than normal;no heat
Sounds a little louder than normal and there is no heat. Turntable and light come on. All else sems to be functioning properly.
  • Sharp Master
  • 9,098 Answers
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
(even if the magnetron passes these tests, it can still be bad. If you have high voltage and the diode is good, assume the magnetron is bad)
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So please reply back directly to me with your brand and full model number from the tag in or on the unit for more help or free do-it-yourself tips or an estimate if required.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 28, 2009
WHEN I TURN ON MICROWAVE OVEN LIGHT COMES ON POWER TO TURNTABLE B UT NO HEAT IN OVEN?
Most likely either the magnetron is bad or a bad diode. Does the unit sound louder than normal? Buzzing?
Dec 05, 2014 | In Microwave Ovens
GE spacemaker xl microwave oven will not heat
My guess is the magnetron is bad. It is rarely the transformer
Jan 04, 2013 | GE Profile Over the RanMicrowave....
The keypad works; the microwave can be turned on and turntable turns round, the light is on, the motor sounds (a little louder than normal) but no heat can be generated. What could be causing this?
No heat would mean the magnetron circuit has failed. It's the part that generates the microwaves that heat the food. If it is making a loud buzzing noise, it could mean that the magnetron or the high voltage diode has failed. Since there exists high voltages inside the oven, would require a qualified service person to repair. However, if the magnetron has failed, would recommend buying a new oven since the parts alone can cost as much as a new oven.
Dec 06, 2010 | Microwave Ovens
Microwave model MV-1510M is not heating, also sounds louder. Everything else is working, fan, lights, turntable etc..
If everything is working normally, except for heating, the likely cause is the magnetron.  Microwaves can be dangerous to work on, as the site below points out.  If you have an ohmmeter, it is possible to check the magnetron, but be certain to follow the precautions outlined at the webpage:
Oct 08, 2010 | LG LMV1680ST Microwave Oven
Turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
May 31, 2009 | GE Profile Spacemaker Over-the-Range...
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
GE Spacemaker Microwave, Model J VM1650AB5 Not heating food
If you sure that lauder sound comes from turntable motor than it needs to be replace.
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My micro wave will not heat products. All other systems are functional.
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Aug 08, 2008 | GE Microwave Ovens
Won't heat
Aug 01, 2008 | Maytag MMV5207A Microwave Oven
GE JVM1440BD Won't Heat
If it making a louder than normal humming or grunting sound when operating, than it's a sure bet it's the MAG.
Jun 09, 2008 | Microwave Ovens
Sharp R-1481B Microwave Oven Logo
114 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
