Question about Husqvarna Sewing Machines
My 5 year old Huskystar 216 sewing machine is
My 5 year old Husqvarna Huskystar 216 sewing machine is making a very consistent 'chain stitch' on the underside of the seam with the top thread. No adjustment of top or bottom tension alleviates this problem. Cleaned thoroughly, put in new bobbin and top thread, fresh needle, top tension set at 4, etc. Was sewing perfectly last time it was used one month ago. Why the sudden change? Didn't drop it, etc. Please walk me through a fix if possible. Much appreciated. Daphne.
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Sounds like the hook/needle timing. To check do the following:
With the power off!!
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding in the right direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to get a good stitch, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Posted on Sep 26, 2009
Twin needle
Hello
Install the second spool pin.
Place the two spools on the spools pins, one on each spool pin.Make sure that the spools are spinning toward each other.
Thread as for single needle.
Thread each needle from a different spool.
Caution: Make sure that the stitch width is not wide than the twin needle maximum swing. Check that the needles will not hit the throat plate as they swing from left to right and back again on stitches with width.
Happy twin needling
Sewingirl/
Jan 30, 2014 | Husqvarna Huskystar 207 Sewing Machine
Husqvarna Huskystar 207 Sewing Machine not stitching. It won't pull the bobin thread up to sew.
Be sure not to use Singer Needles. They are longer than standard needles. Don't know if this helps, but I did this once on my Huskystar 207 and that is what happened. It also damaged the bobbin thread.
Fairleigh
Sep 18, 2011 | Husqvarna Huskystar 207 Sewing Machine
I cannot ser a straight stitch with the needle in center position. The manual does not state how to adjust needle position (left, center, or right). Because the needle is in the left position and the...
Some machines are not designed to sew the straight stitch with the needle in the center position. Some are left or right position to do that and it is simply the way they were designed. Linda at Relics
Jul 04, 2011 | Husqvarna Huskystar 215 Sewing Machine
I have inherited a Husqvarna 4500 from my mother. Everything was working beautifully until I ran out of cotton on the bobbin. I read the instructions and did as directed. When starting to straight sew...
This is not a solution but I am actually looking for the instructions/manual for a 4500 Husqvarna Viking sewing machine. Would appreciate any help. Thank you.
joli.harrington@gmail.com
Jan 05, 2011 | Husqvarna Huskystar 207 Sewing Machine
Hi, I'm trying to sew a silky fabric and the stitches on the bottom keep getting jumbled and the top thread breaks
My guess is that you have lost all of your upper tension and you may have your needle in backward.
Unthread the machine.
Raise the presser foot. Turn the handwheel until the take-up lever is at it's highest position. Set the upper tension dial/knob to 5. Remove the needle and replace it making sure that the flat side of the needle shank is to the back. Thread the machine.
With the presser foot up, the upper thread should pull through easily and then grab when the presser foot is lowered.
Test sew.
The upper tension pulls the stitches up and the lower tension pulls the stitches down. When they pull properly, the stitch is even.
Oct 29, 2010 | Husqvarna Huskystar 215 Sewing Machine
Won't form a chain stitch
You 910 serger doesn't have the option for a Chain Stitch. It is a 2, 3, or 4 thread serger. You can do a good number of different stitches but a chain stich is not one of them.
If what you mean it that it won't "chain off", meaning sew with no fabric beneath the foot as you gently pull the thread towards the rear of the machine, that could be for a number of different reasons. First, change the needles and unthread the machine and start over. If the threads are not exactly where they should be, your serger won't sew correctly. A great video on threading your machine can be seen at:http://www.husqvarnaviking.com/mediafiles/huskylock/index_en.html
Sep 12, 2009 | Husqvarna Sewing Machines
Sewing Machine Stops
this sounds like its set for zippers check settings!
Dec 09, 2008 | Husqvarna Sewing Machines
Sewing Machines Logo
304 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
