Question about Hotpoint Ultima WF860 Front Load Washer
WF860 Door stuck in closed position.
The door on my washing machine is stuck in closed position. It feels like the handle is broken, there is no water etc in the machine, how do I get the door open and reapir the handle?
Couse
  • 32 Answers
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Posted on Apr 13, 2008
    New Friend:
Thank you, Malcolm. I followed your advice and it worked perfectly.
Posted on Mar 18, 2013
My Tenants have broken the door release handle on this WD860 and I need to get the door open to remove the clothing and dismantloe the door for repair. How can I do this?
Remoove plug from socket, then remove top from machine I think on this model you will need to remove the small caps on side of the top. Then there are 2 screws to remove this will allow the lid to be removed. then you can normally reach inside to release the door.
Feb 25, 2011 | Hotpoint Ultima WF860 Front Load Washer
Door handles slack feels like springs dropped so cant open door
You can release the catch from inside just keep trying and thern you need to replace the door catch itself this is a simple job
Jun 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Red light about door icon flashing
Sounds like a door lock problem. May just be a weak spring in the door handle which helps push the door lock pin against the contacts in the door lock switch. If you open the door and push on the pin or operate the handle the pin should return positively to its closed position, if very weak return then spring wants replacing. Take door apart to gain access to handle and spring and replace spring if broken.
Feb 14, 2010 | Washing Machines
Door will not close
It could be a faulty door interlock, or a broken or weak spring in door handle.
You would need to take the door apart to check this..
What ever is the problem, it is related to the lock or door handle.
Hope this helps.
Jan 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Door handle will not return to latched position
the spring in the door handle assembly is broken,the spring is replaceable seperatly.
Aug 22, 2009 | Washing Machines
Doors won't close
Manually UNLOCK the door button or slide. HOLDING the OUTSIDE DOOR HANDLE in the OPEN position, with your other hands finger, LIFT OPEN the latch, and close your door. Hope this helps.
May 24, 2009 | 1994 GMC Sierra
Washing machine White-Westinghouse LB-42 door stuck?
The Inside Handle was Broken (from Iside) ! I had to remove the cover and replace the broken handle !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 14, 2008 | Hotpoint WF430 Front Load Washer
Zanussi FL884 Washing Machine
there is no emergency release.
two ways of opening door.#
break handle off and you can lever door peg with a small screwdriver
or
disconnect from mains
take top off. feel down to the door interlock and feel for the end of the door peg. push this sideways and you can sometimes release the door
Oct 03, 2008 | Zanussi Washing Machines
Wahing machine Tricity Bedix AW1260W-Door problem
probably handle mechanism broken. to open is a bit difficult.
disconnect from mains and take top off.
feel down the cabinet front on the side where the door handle and opposite the door handle you will find the door interlock. in the door interlock, you will find the end of the door peg. force this towards the middle of the machine and with luck the door will open.
anothetr method is to break the handle off and use a small screwdriver on the door peg
Jul 21, 2008 | Tricity Bendix AW1200 Front Load Washer
Help needed indesit washing machine
well it would help to know brand/model#
Oct 03, 2007 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
637 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
