I've tried on a number of occasions to print to my wireless brother 6490CW printer that is stationed only 2'-0" away but cannot seem to get any readings to print. Both my PC and labtop were working and reading the 6490 at one point, but for some reason I can no longer print from both stations. How can I fix this problem?
SOURCE: Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
SOURCE: I have a Brother MFC 6490cw and can't Get The
if you have done a couple cleanings and it has not helped, its one of 2 things, either your ink cartridge is empty and needs to be replaced, or the nozzles are clogged on the printhead, also air can be in the turbing causing it not to let the liquid flow.
thanks adi
SOURCE: BROTHER MFC-6490CW won't connect to wireless router
have you found a solution? I just purchased brother wireless printer, same thing, called and they said it must be my router. I haven't had a chance to play with it as much as you have, but before I do was wondering if you found a way to make it work yet?
SOURCE: I have recently installed a
You have 2 printers because it was inadvertently installed twice. You need to un-install both of them and reinstall the printer again.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
