Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Does the exhaust vavle have a stem seal on a intek twin cylinder?
  • 148 Answers
Most do not. Check your exact model/type/code numbers on the parts lookup site here.
Posted on Sep 26, 2009
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
21hp intek engine one cyclinder smoking badly when going up hill
It either has a scored cylinder and piston or a broken piston oil control ring or both
Nov 07, 2012 | Cars & Trucks
20 hp intek v twin one side is over carbureting .how do I correct this
have you checked your oil if the gas ran into your oil it will come out one cylinder before the other
Sep 19, 2012 | Briggs & Stratton Briggs Stratton Intek V...
One cylinder not firing
check compression hot and cold both cylinders there should be at most a 5% difference in compression values. if compression is low in the one in question than be paired to rebuild the unit.
Aug 08, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a briggs 24 hp twin v intek engine, started smoking last year with only 50 hours, now with a little over 60, it smokes like a steam train and uses 1 qt oil/30 min. Last week it fouled a plug, I...
Double check that the head bolts are properly torqued.There is a crankcase breather if stuck open could be drawing oil into the intake, and there is a valve stem seal on each intake valve that could be leaking. All this is assuming that the oil level is not over full. They will smoke like a banshee if they have to much oil in them.
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
How do set valve lash
Turn the motor until the piston is at TDC. Look through the spark plug hole. piston to top of the cylinder. Then set them like you would any OHC rocker arm. BE very careful with the exhaust valve adjustment. There is like a mini disc on top of the valve stem spring keeper. If you get it too loose on a vertical engine it can drop out and it will take you forever to find the little bugger!
Below is only a recommendation....
I don't know how many hours that are on this engine your working on but... I would recommend you hand lap the valves with grinding compound if you know it has high engine hours. It will make it easier to start and have more power. The exhaust valves on these engines get very noteable black gunk buildup in the seat to the point you can not see the "valve to seat" mating ring on the valve head. The heads are not hard to remove... (One at a time) just time consuming. It can be a chore getting the valve push rods aligned with the engine horizontal. Most of the time and I know good Mechs don't like to hear this.. you can reuse the cyl head gasket on this model due to the design. Once in a while they break not very often.
The valve springs have keyhole locks on the keeper.
Thanks for using FixYa,
Kelly
Apr 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine smokes . is it worth fixing
Hi and welcome to Fixya. The smoking can be stoped with a new set of rings and some hand lapping of the valves and seats with grinding compound. If your a fair mechanic it would be worth the effort. A new 20 HP v-twin will set you back a good bit of money. The parts can be ordered either on line or you can get them at a local lawn mower parts supply. Rings are about $35.00 per cyl and the the gaskets are relatively cheap. Valve grinding compound you can get at any automotive parts store. Buy a new set of valve stem seals also if you do fix it.
I have seen new LT120's listed in the $1999.00 - $2299.00 price range.
Your call as to fix it or... not purchase the unit. Depending on the asking price.... and the condition of the Lawn Tractor it might be worth the time and effort.
Kelly
Apr 18, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I am blowing oil out of the vent from the valve cover on a 70's 6040. Any answers to this problem?
This is called blow-by. Start with compression test to find out is rings are ok. Need more information like gas diesel, model number of engine. So here is a general run down. Compression is getting into crank case. Several things can cause this. Possible causes are bad valve guides, rings, head gasket valve stem seals. Compression test will tell if low cylinder. If this is ok for your year model look to valve stem seals. If two cylinders next to each other low. Possible head gasket leak. Use compressed air 60-90 psi and listen were air is going. If blowing into crank case or intake exhaust manifolds. If crank case rings if not valves. I am going to assume your engine is burning oil or using more then normal. Possible white smoke from exhaust. If this is the case and compression is good valve stem seals should fix it. Hope this helps. Remember when compressing cylinders have both valves closed on top dead cylinder.
Mar 18, 2010 | B&C Allis Chalmers Tractor B,c,ca...
15.5 intek pushrods whitch one is for the intake vavle ?
Intake is aluminum, exhaust is steel. Set valves 1/4" past top dead center on compression stroke (both valves closed), intake (bottom) .003-.005, exhaust .005-.007
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
399 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
