Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
Posted on Sep 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY LOWER DISHWASHER DRAWER IS "GRABBING" AS I PULL THE DRAWER OUT. HAVING LOOKED AT IT CLOSER THE PLASTIC LOCKING LATCH AT THE BACK OF THE DISHWASHER(ON THE LEFT HAND SIDE)IS BROKEN.DO YOU HAVE A PART # FOR THIS PIECE AS WELL AS A PICTURE?
Sam
Level 3:
  • Fisher and P... Master 3,247 Answers
  • Posted on Nov 08, 2009
Sam
Level 3:
Answers
3247
Questions
0
Helped
1306324
Points
10378
You can download the parts manual for the DD603H from fisher and paykel and check which latch you need. The diagrams are given in it.
http://kitchen.manualsonline.com/manuals/mfg/fisher_paykel/dd603h.html
DD24DCX7 Dishwasher - Top Drawer Not Working
Hi Brendan,
The dishwasher will stop mid cycle if the door is not closed properly, please ensure that the door is shut firmly and the latch engages fully.
Also a broken door latch, faulty control panel or failed electronic control board could be causing the problem.
Hope this helps.
Best,
Dan
My Bosch dishwasher door latch is stuck in the locked position--anybody know how to reset it?
Happened to me as well. Pull the latch (looks like an upside down house) towards you and it will click back into position. Needs a bit of force but it should do the trick!
Apr 09, 2017 • Dishwashers
Fisher and Paykel dish drawer, rotor won't spin freely
test this steps and fix it. God bless you
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
The door won't latch
The most common problem with the door not latching is the top rack not being completely in the back position. Check the rack to make sure that there is nothing jammed and not letting the rack completely close, also make sure that water tube lines up. On most models there is not real adjustments for the door latch.
2helpful
How do I turn off the flood switch sensor on a fisher and Patel double drawer dishwasher
Unfortunately there is no way to turn the flood sensor switch off, you need to pull the lower drawer all the way out and check for any water in the base or other items affecting the flood switch, If you have a 601 series you need to pull the 2 round pins out on the front sides of the drawer to enable you to pull the drawer out enough to get to the flood switch, If you have a 603 series you need to push in the 2 locking tabs on the front side of the drawer which will allow you to pull the drawer out enough to check the switch. Make sure you unplug the dishwasher before doing this,
2answers
How do you replace the electrical cord on a dd603
You would need to remove the lower drawer and the plastic cap on the mains filter board. The link below explains how to remove the lower drawer and access the main filter board.
The plastic cap is held down with small tabs, depress the tabs and slide the cover off. The power cord is screwed down to the mains filter.
Fisher Paykel Dishwasher Repair Video
3helpful
2answers
Unfolding the treadmill
1. Hold the upper end of the treadmill with your left hand. Pull the latch knob to the left and hold it. Pivot the frame downward and release the latch knob. Note: To release the latch knob, it may be necessary to push the
frame forward as you pull the latch knob to the left.
2. Hold the metal frame firmly with both hands, and lower it to the floor. CAUTION: To decrease the possibility of injury, do not lower the frame by gripping only the plastic foot rails. Do not drop the frame to the floor. Make sure to bend your legs and keep your back straight.
Top drawer doesn't 'seat' itself -- give error tone wont start
You need to take out the tube to see the 2 latches at the end of the 2 rails still has spring attached. The 2 latches keep the tunb in the place when it closed. They are replaceable
The white plastic guide is broken because of the the brittle plastic and it is OK.
12helpful
3answers
Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Top Fisher and Paykel Dishwashers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
