Question about Microsoft Xbox 360 Console
Xbox 360 I have an xbox 360 older version without the hdemi port. is their any way i can hook my console up to my hd tv via the hd slot on my tv, to get the full effect.this seems to be another rip of from microsoft with the new elite with the port.
  • Anonymous Nov 05, 2008
    yes i have the same problem. i think its time to buy an elite.
    this problem has been driving me mad for ages now.
    sorry
The answer is madcatz:
Mad Catz HDMI Conversion Kit
http://www.madcatz.com/Default.asp?Page=411&CategoryImg=Xbox_360_Accessories
Posted on Nov 05, 2008
    Problem Solver:
  • 13 Answers
Hi there
As far as I'm aware the only way to get hd with the older boxes that don't have hdmi socket is through component unfortunately.
Microsoft have indeed pulled a fast one with this and cunningly released the elite for more profit.
I think the only difference betwen component and hdmi is that hdmi has built in audio in one wire where as with component you require seperate audio.
In short, No. HD only via component.
Hope this is of help
Posted on Dec 18, 2007
When I hook up my xbox 360 to a floor model flat screen that is probably 7 or 8 years old, there is sound but no picture. When we hook it up to our newer model flat screen everything works fine. Can you...
Are you trying to use HD? Component cables or HDMI? Component cables limit you to 720p. It's possible that your old TV doesn't support 720p or there is something wrong with the jacks. What sort of connections do you have?
Sep 03, 2010 | Microsoft Xbox 360 Console
Hooking up an xbox 360 console to a 50 '' plasma tv hd need a diagram
A few questions.........what model are you using and what kind of connection??
I have a PN50A450 from Samsung and use HDMI. I also need to know what kind of 360 have(newer or older,HDMI out of none)
Jul 08, 2010 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 nothing displayed on the screen
first make sure the switch on your cable is on "tv" not "high def"
Jun 01, 2009 | Microsoft Xbox 360 Console
You need to set the monitor up. I have a 42" LCD TV, and there is a menu where you can set the aspect ratio to 'Auto', 'Full Screen', or "4:3". I had a similar issue with my DVD player. I'm sure if you go through your monitor setup menu, you should be able to solve this problem.
Apr 17, 2009 | Video Game Consoles & Games
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
X box looks like it starts up but the screen will stay blank
Check the status of the "HD" switch on the side of the video connector, nearest to the Xbox. I have the same non-HDMI Xbox. If I have it hooked up via component to a non-HD TV, and the switch is on "HD", it will show no video.
Nov 22, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Hooking up XBOX 360
Hi have you tried going into the menu option using the telly controll and switching the hd mode on this should then allow you to use the xbox through hdmi cable
Feb 29, 2008 | Proscan 42LA30H 42 in. LCD Television
When i connect my 360 to my tv i only get sound and a flashing screen. why?
Maybe it's a bad video port on your TV. Try hooking it up on another video port on the TV. I've had this same problem because the front video port on my TV was bad. I hooked it up in the back port of the TV and it worked.
Dec 20, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
78 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
